This guide describes how to replace the motor assembly from inside of the BLACK and DECKER BDERO100 5 inch sander. The tools that you will need for this process are the TR20 Torx Security bit driver or equivalent, the plastic spudger & the plastic opening tool.
Remove the sanding paper from the velcro.
Select the JIS - J1 bit or the most appropriate bit to match the screws for your model.
Use the Bit Driver to take off the four 12.5 mm Phillips screws at the base of the hook-and-loop system.
Once all screws and washers have been removed, hold the hook and loop system and separate it from the device.
Where can I find the right pad for this model?
Where can i find the white rubber that is under the loop system, it is broken
I need the white rubber seal, does anyone know the parts number?
Use the nylon spudger to remove the rubber ring from the filter attachment section.
Use the TR20 Torx Security bit driver to unscrew the five 18.75mm Phillips screws from the warning label side of the chassis.
Grab the plastic opening tool and place it on the separation line between both sides of the chassis.
Separate both sides and open the device.
Hold the chassis and separate it from the device.
Use the bit driver with the JIS - J1 bit to remove the two 12.5 mm phillips screws holding the cord clamp to the chassis.
With yout hands, hold and separate the power button from the external case by pulling gently.
Hold the motor and gently pull to remove from chassis.
Gently pull on all cables connected to the motor to remove.
Once all cables are disconnected, you can proceed to replace the motor.
Hey, I’m planning on changing the motor on my B+D 20V Sander and it seems to be the same (or at least very similar) procedure, but I’d like to know the type of motor it needs. Do you know how can I know the specs of the motor? or is that more of a open and see kind of thing?
Thanks!
Diego Alejandro, Avilan Franco - crwdns2934203:0crwdne2934203:0
