Bissell CrossWave Cordless Max 2554A Battery Replacement
  1. Bissell CrossWave Cordless Max 2554A Battery Replacement, Battery Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bissell CrossWave Cordless Max 2554A Battery Replacement, Battery Assembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 16 mm Phillips #2 screws at the back of the vacuum and below the clean water tank.
  2. Bissell CrossWave Cordless Max 2554A Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bissell CrossWave Cordless Max 2554A Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the battery assembly away from the main body.
    • There are still wires connecting the battery assembly to the main body. Do not use force to completely separate the two objects.
  3. Bissell CrossWave Cordless Max 2554A Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bissell CrossWave Cordless Max 2554A Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Detach the wires holding the battery assembly to the main body by pressing down on the clip holding the connector together.
  4. Bissell CrossWave Cordless Max 2554A Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Bissell CrossWave Cordless Max 2554A Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Bissell CrossWave Cordless Max 2554A Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • This step involves cutting live battery wires. If possible, use insulated cutting equipment and do not touch the exposed wires. Use wire cutters instead of the scissors shown in the images.
    • Cut the remaining yellow and black wires to detach the battery from the main body.
    • These wires do have a device connecting them to the wires on the main body, but these devices are unable to be removed without specialized equipment.
  5. Bissell CrossWave Cordless Max 2554A Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bissell CrossWave Cordless Max 2554A Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The main body can now be set aside until reassembly.
  6. Bissell CrossWave Cordless Max 2554A Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bissell CrossWave Cordless Max 2554A Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four silver 13.5 mm Phillips #2 screws.
    • Do not remove the two visible black screws. They hold the two halves of the battery case together and should not come apart.
  7. Bissell CrossWave Cordless Max 2554A Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bissell CrossWave Cordless Max 2554A Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the battery out of its housing.
    • Solder the wires from the new battery to the wires in the main body of the vacuum.
To reassemble your device, follow these instructions in reverse order. Make sure you properly insulate the wires that were cut when reconnecting them.
Craig Bowlin
crwdns2935283:002/15/24crwdne2935283:0
1 006 crwdns2915208:0crwdne2915208:0
University of Memphis, Team 4-2, Sneed Spring 2024 crwdns2935289:0University of Memphis, Team 4-2, Sneed Spring 2024crwdne2935289:0
UM-SNEED-S24S4G2
I have the crosswave 2554 a I want it as a raffle and I let it sit in the closet for over a year and when I went to plug it in the battery was dead can you tell me what the part number is I'm having the hottest time trying to find a battery replacement battery
Lisa Arthur - crwdns2934203:0crwdne2934203:0
Bissell P2921 / 69-0096-041
김민석 -
How do you. Change the battery ends are different. The ones with the white square ends . One has six to plug in the other is 8 to plug in But is the battery for my Bissell cordless is the right battery everything on the batterys match
Linda - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 126
crwdns2942667:0crwdne2942667:0 2,485
