The audio amplification PCB is the PCB which has the task of amplifying the B212D speaker's input signals.
Remove the 8 Phillips screws from the back of the speaker.
Carefully remove the back panel, lifting out the metal electronics-box with it.
There are two silver, 6 mm-long machine screws with two 1/8" inner-diameter washers on the exterior of the metal electronics box; remove these first using a #2 philips screwdriver.
There are five of the same type of machine screw (silver, 6 mm-long) remaining around the metal electronics box's exterior; remove these as well.
Remove the portion of the metal housing that you freed with the 7 screws in the previous step.
Inside the metal electronics box housing is a white clip attached to a small PCB; remove this.
Snake the clip head through the hole in the metal electronics box casing.
Remove the 4, 7/32" long machine screws with a #2 phillips head screwdriver.
Rotate the back panel so you can view the interior; note the three wires attached.
Remove the wires to you can fully remove the back panel.
Remove the 2 indicated flat head machine screws indicated using a #2 phillips head screwdriver.
Remove the 2 indicated flat head machine screws using a #2 phillips head screwdriver.
Remove and set aside the metal panel that was separating the small PCB from the audio amplification PCB.
Note the 4 large flat head machine screws which hold the clamps on the opposite side; remove them with a #2 phillips head screwdriver.
Note the 3 flat head machine screws holding the heat sink to the metal electronics box; remove them using a #2 phillips head screwdriver.
Note the location of the 4 indicated machine screws which hold the audio amplification PCB to the metal electronics box; remove them using a #2 phillips head screwdriver.
Remove the audio amplification PCB from the metal electronics box.
If you haven't already, remove the heat sink from the IC's, being careful not to get any of the ceramic thermal paste on your skin, as it is difficult to remove, even with soap.
Hi I need replacement parts for the Behringer b212. Where can I buy them?
shannonleggettemusic@gmail.com
Hi very good tuto but same question ... where i can buy the Audio Amplification PCB? lestyx@wanadoo.fr
Same problem, I need one too.
crwdns2935229:05crwdne2935229:0
Bonjour a tous
Mais ou trouve t'on les pièces détaché
Cordialement
lol pareil je cherche la pcb
I need the schematic for this unit can you help I have +12v missing +and - 15v
mattox_64@hotmail.com
I need the panel where I buy it
Calde.dc@GMAIL.COM
i need value of t15 and 16. please
Cho toi so do thiet bi nay k
Eurolive B212d back plate requirement
Ashok Ahlawat - crwdns2934203:0crwdne2934203:0
