Beats Pill 2024 Motherboard Replacement
  1. Beats Pill 2024 Motherboard Replacement, Subwoofer: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the strap.
  2. Beats Pill 2024 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Beats Pill 2024 Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the Beats Pill sitting on a flat surface, insert a spudger into the seam between the chassis and grille.
    • Slide the spudger around the entire perimeter of the grille to sever the adhesive securing the grille.
    • Reapply adhesive when reinstalling the grille.
    • Remove the grille.
  3. Beats Pill 2024 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Beats Pill 2024 Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to remove the six stickers on the face of the driver assembly.
    • Place the stickers on a clean surface so as not to ruin the adhesive.
  4. Beats Pill 2024 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the six 14.3 mm screws that secure the driver assembly and speaker body together.
  5. Beats Pill 2024 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Beats Pill 2024 Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a spudger into the seam between the driver assembly and speaker body.
    • Gently slide the spudger around the perimeter while prying to separate the driver assembly from the speaker body.
    • This should not require much force.
  6. Beats Pill 2024 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the two subwoofer connections from their motherboard sockets.
    • Depress the clip on each connector prior to removal.
    • Use tape or a marker to mark where each connector goes.
    • If you're completing a tweeter replacement, skip to Step 8.
  7. Beats Pill 2024 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the four 12.4 mm screws securing the subwoofer.
    • Use a spudger to lift the subwoofer up and off of the driver assembly.
    • This might require some force, as there is adhesive holding the subwoofer to the assembly.
    • During reassembly, apply an adhesive to the new subwoofer before reinstallation.
  8. Beats Pill 2024 Motherboard Replacement, Battery: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Beats Pill 2024 Motherboard Replacement, Battery: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the speaker over.
  9. Beats Pill 2024 Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Beats Pill 2024 Motherboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a hairdryer to lightly heat the bottom foot of the speaker.
    • Insert a spudger into the seam between the bottom foot and speaker body.
    • Pry around the perimeter of the foot until it fully releases.
    • Reapply adhesive to the foot before reinstalling it.
  10. Beats Pill 2024 Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Beats Pill 2024 Motherboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the twelve 8.6 mm T5 Torx screws that secure the battery cover.
  11. Beats Pill 2024 Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Beats Pill 2024 Motherboard Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Beats Pill 2024 Motherboard Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To remove the battery, pull on the tape material wrapped around the middle of it.
  12. Beats Pill 2024 Motherboard Replacement, Motherboard: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two T5 Torx screws that secure the battery compartment.
  13. Beats Pill 2024 Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Beats Pill 2024 Motherboard Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Beats Pill 2024 Motherboard Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to dislodge the battery compartment from its housing.
    • Before complete removal, disconnect the battery compartment motherboard connector.
  14. Beats Pill 2024 Motherboard Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the black ZIF locking tab in the top-right corner of the motherboard.
    • Disconnect the ribbon cable.
  15. Beats Pill 2024 Motherboard Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the seven 12.4 mm Phillips screws securing the motherboard.
  16. Beats Pill 2024 Motherboard Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the motherboard perpendicular to the housing, with care not to strain the connected cable.
    • Disengage the ZIF locking flap and disconnect the ribbon cable.
  17. Beats Pill 2024 Motherboard Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motherboard.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Spencer Baines
crwdns2935283:001/23/25crwdne2935283:0
753 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team 1-6, Virtue Spring 2025 crwdns2935289:0Western Carolina University, Team 1-6, Virtue Spring 2025crwdne2935289:0
WCU-VIRTUE-S25S1G6
crwdns2942667:0crwdne2942667:0 55
