This is a guide describing how to replace the 2024 Beats Pill battery. A battery replacement might be needed after unsuccessful troubleshooting, including trouble charging or a factory reset. This guide provides a step-by-step process to replace the battery and reassemble the speaker.
Use a hairdryer to lightly heat the bottom foot of the speaker.
Insert a spudger into the seam between the bottom foot and speaker body.
Pry around the perimeter of the foot until it fully releases.
Remove the twelve 8.6 mm T5 Torx screws that secure the battery cover.
To remove the battery, pull on the tape material wrapped around the middle of it.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
