Base Removal
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Base Removal, Uncover the back panel screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Base Removal, Uncover the back panel screws: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin, completely power down and unplug all cables from your console.
    • Two stickers cover the back panel screws. You can remove the stickers without heating them, though it makes them much easier to remove cleanly.
    • Heat an iOpener and lay it on the smaller sticker near the bottom of the back panel for two minutes.
    • Alternatively, you can use a hair dryer to heat the sticker.
  2. Base Removal: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Base Removal: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Base Removal: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of angled tweezers to remove the sticker hiding the first screw on the back panel, near the base.
  3. Base Removal: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Base Removal: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Base Removal: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use an iOpener or hair dryer to heat the larger sticker near the center of the back panel.
  4. Base Removal: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Base Removal: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Base Removal: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger to scrape up a corner of the larger sticker until you can grip it with a pair of blunt tweezers.
    • Use blunt tweezers to peel back the sticker to reveal the second screw.
    • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
    • Technically, these are tamper-evident stickers, but don't worry—Microsoft can't legally void your warranty, as long as you don't damage anything. Have fun!
  5. Base Removal, Remove the back panel screws: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Base Removal, Remove the back panel screws: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Magnetic Project Mat
    $19.95
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
    • Use a T8 Torx driver to remove the two 7.4 mm‑long screws securing the back panel.
  6. Base Removal, Unclip the back panel: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Base Removal, Unclip the back panel: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Base Removal, Unclip the back panel: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
    • Pry up the back panel to release it from the locking clips.
  7. Base Removal: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Base Removal: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Base Removal: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the right side of the base.
  8. Base Removal, Remove the back panel: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Base Removal, Remove the back panel: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Base Removal, Remove the back panel: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
    • During reassembly, press along the edges of the back panel to snap it into place.
  9. Base Removal: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Base Removal: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Base Removal: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The back panel slots into a gap at the top of the shell.
    • Tilt the back panel up and pull it away from the top edge of the shell to release it from the gap.
    • Remove the back panel.
  10. Base Removal, Unlatch the base: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Base Removal, Unlatch the base: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Base Removal, Unlatch the base: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger to pry up the locking tab holding the base to the shell.
    • Keep the locking tab held open for the next step.
  11. Base Removal, Twist and remove the base: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Base Removal, Twist and remove the base: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Base Removal, Twist and remove the base: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the locking tab held open, grip the base and rotate it counterclockwise to unlock it from the shell.
    • Remove the base.
    • During reassembly, put the base tabs into their holes on the shell and twist clockwise until the base snaps into the interior locking tab.
    • When locked in place, the Hello from Seattle line will be parallel with the device's sides.
Spencer Day
crwdns2935283:009/14/22crwdne2935283:0
116 507 crwdns2915208:0crwdne2915208:0
crwdns2935297:0837crwdne2935297:0
Staff
crwdns2935297:020 626crwdne2935297:0
crwdns2942667:0crwdne2942667:0 42
