This guide is a prerequisite for the following guides: [crwdns2936915:0crwdne2936915:0]. It is not intended to be used as a standalone guide as it is used when integrating steps where I need standardized instructions. It will make no sense as a solo guide.
Setup a backdrop support. This can be anything from a trifold board cut in half (the style you used in "school") or a custom design. I chose a custom design to conform it to my design spec and make the modifications I wanted.
Setup your white background. Once the backdrop is stable, minimize as many unsightly areas as possible. You are ready.
Take a few test photos (Optional). If you are unsure about the end result, take 1-2 test shots for review. Make adjustments until you are happy with the end result.
Place a few support brackets on the lower piece. Add screws as your brackets permit.
Hold the top piece up and add screws to the top side.
Once assembled, you are ready to use the backdrop.
