If you are having problems with your turn table not spinning and have not found the cause to be a problem with the power or wiring, you may have a faulty Regulator on your board that is preventing power from reaching the motor.
Use a Phillips #2 screwdriver to remove the four 2.5 mm screws.
Identify the Precision 500 mA Regulator.
If there is RTV Adhesive Glue, slightly pull back and forth on the Precision 500 mA Regulator to loosen the glue and break it free.
Flip the board that was loosened from removing the four screws and go on the opposite side of where the Regulator is located. Desolder the regulator.
Remove the faulty regulator.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
