Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement
  1. Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement, Outer Shell: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement, Outer Shell: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement, Outer Shell: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the inner steel plate that spins on the turntable.
    • Carefully lift up the plate.
    • Place it near your device out of the way.
  2. Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the power cord in the back of the device.
  3. Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Ensure that the Tone Arm clamp is in place.
  4. Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #2 screwdriver to remove the eight 2 mm screws holding the back casing into place.
    • Carefully remove the back casing from the device to expose the interior.
  5. Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement, Anti-Skate Knob Spring: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement, Anti-Skate Knob Spring: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement, Anti-Skate Knob Spring: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The Anti-Skate Knob is in the top left corner of the record player; this is what holds together the Tonearm.
    • To remove this, you must desolder the five small connections and the large one next to it.
  6. Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #2 screwdriver to remove the two screws.
    • Using Snap Ring Pliers, pull up at the Snap Ring to remove it.
  7. Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 2.5 mm screws using a Phillips #2 that connects the tonearm to the record player frame.
  8. Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the cable with the Phillips #2 screwdriver.
  9. Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Philips #2 screwdriver to remove the two 2.5 mm screws, and remove the Snap Ring by pulling up at it with Snap Ring Pliers which are being highlighted.
    • DO NOT unscrew the yellow X in the picture.
    • Remove the small 0.1 mm black screw with the Phillips #000 screwdriver.
  10. Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull off the cover to reveal the spring.
    • Using Tweezers, pull the spring out by pulling it off of the hooks on each end.
  11. Audio-Technica AT-LP120-USB Anti-Skate Knob Spring Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now replace the old spring with your new one!
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Ryan Barcelos
crwdns2935283:010/31/24crwdne2935283:0
345 crwdns2915208:0crwdne2915208:0
Cuesta, Team 20-3, Krynen Fall 2024 crwdns2935289:0Cuesta, Team 20-3, Krynen Fall 2024crwdne2935289:0
CUESTA-KRYNEN-F24S20G3
Hi
Where i can find to by antiscate spring?
Thanks
Flegma - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 272
