This guide will help your install a new driver.
Remove the ear pads by peeling them away from the grill.
Remove all four 1cm screws on the inside of the headphone using a #1 Phillips head.
Remove the speaker from the grill by pulling it out.
With a #0 phillips head, unscrew the three, 1 cm screws which are holding the driver (red wafer) in its bracket.
Remove the two wires, red and yellow, by de-soldering them from the driver using a soldering iron and desoldering wick. Reference How To Solder and Desolder Connections.
Connect the existing wires to the new driver by re-soldering the wires using the soldering iron.
Using the copper as a reference, re-solder the yellow wire to the top left solder joint and the red to the bottom left solder joint.
where can i buy a replacement driver?
You can order parts directly from PARTS@ATUS.COM
My jbl waerless headphone speaker changes how price
Max Mad - crwdns2934203:0crwdne2934203:0
How to install the earpads
rangaranju - crwdns2934203:0crwdne2934203:0
