Audio Technica AT-LP60BK Motor Replacement
  1. Audio Technica AT-LP60BK Motor Replacement, Turntable Motor: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Audio Technica AT-LP60BK Motor Replacement, Turntable Motor: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Audio Technica AT-LP60BK Motor Replacement, Turntable Motor: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before starting, ensure the unit is not plugged into a wall outlet or output device.
    • The hinges for the clear lid will slide vertically out of the case when the lid is in the open position.
  2. Audio Technica AT-LP60BK Motor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Audio Technica AT-LP60BK Motor Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Audio Technica AT-LP60BK Motor Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the felt mat from the turntable deck to expose the metal platter below.
    • Remove the belt from the motor spindle (brass cylinder) to be able to remove the platter.
  3. Audio Technica AT-LP60BK Motor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Audio Technica AT-LP60BK Motor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Audio Technica AT-LP60BK Motor Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the metal turntable platter by gripping as shown and pulling straight up until free.
    • The brass cylinder shown is the spindle that drives the platter that is attached to the motor that is being replaced.
  4. Audio Technica AT-LP60BK Motor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the whole unit over, and remove the four screws indicated in red using the Phillips #2 screwdriver.
    • Remove the two feet indicated in orange using the Phillips #2 driver. The other two feet do not need to be unscrewed to remove the case.
    • Remove the bottom lid by carefully lifting straight up. Do not force it, the lid should remove easily.
  5. Audio Technica AT-LP60BK Motor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Audio Technica AT-LP60BK Motor Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Audio Technica AT-LP60BK Motor Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The drive motor will be on the right side and in the upper half of the unit. The drive motor within this unit is displayed as it was found in the unit in the first photo.
    • The motor in this unit was a SANKO 9V, 12V CW (clockwise) MO9S12U13-3 60622T C. Verify the motor model before ordering a replacement.
    • Note the polarity of the wires leading to the motor. This unit is wired as follows, according to the markings on the motor body: (NOTE: if the wiring varies on other units, use that wiring schematic.)
    • A - Yellow
    • B - White
    • '+' - Black
    • '-' - Red
    • De-solder the connections to the motor. Be careful when using a soldering iron so as not to burn yourself. Do not hold the iron in one place for too long to prevent burning and damaging the circuit board. For more information on soldering connections, please read the How to Solder and Desolder Connections guide.
  6. Audio Technica AT-LP60BK Motor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Audio Technica AT-LP60BK Motor Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the unit over and using the Phillips #1 screwdriver, carefully unscrew the two indicated screws that hold the motor in place.
    • Carefully flip the unit back over and remove the motor by gently lifting straight up.
  7. Audio Technica AT-LP60BK Motor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Audio Technica AT-LP60BK Motor Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The new motor should be inserted and attached to the case in the opposite manner of the last step.
    • Solder the new motor, making sure to attach the colored wires in the same manner as they were removed.
    • Be careful when using a soldering iron so as not to burn yourself. Do not hold the iron in one place for too long to prevent burning and damaging the circuit board.
  8. Audio Technica AT-LP60BK Motor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Audio Technica AT-LP60BK Motor Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Reassemble the unit by following Steps 1-4 in reverse order.
    • Note the indicated holes on the bottom of the case. These lead to the motor to adjust the speed at which the turntable spins.
    • The orange indicator leads to the 33 rpm speed control.
    • The yellow indicator leads to the 45 rpm speed control.
  9. Audio Technica AT-LP60BK Motor Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Audio Technica AT-LP60BK Motor Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Audio Technica AT-LP60BK Motor Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Flathead 1.5 mm Screwdriver
    $5.49
    • With the unit fully reassembled, test the speed of the motor by comparing the output of the turntable to a digital recording of the same song.
    • With the unit OFF and unplugged, adjust the speed by inserting the 1.5 mm Flathead screwdriver into the shown holes and carefully turning the screw in the motor housing. This step is very sensitive and will likely take multiple attempts to get the speed just right.
    • NOTE: do not adjust the speed of the unit while the motor is turning, as this is likely to damage the motor or cause injury.
    • Reinsert the lid and enjoy your repaired Audio Technica AT-LP60BK turntable.
    Do you know the operating voltage of the unit. I need to change a failed transformer and cannot find it. I think it's 12vac secondary and that converted to 12vdc
    Eric Montambeault - crwdns2934203:0crwdne2934203:0
Michael Lynch
crwdns2935283:010/29/19crwdne2935283:0
196 crwdns2915208:0crwdne2915208:0
University of Memphis, Team S1-G8, Willis Fall 2019 crwdns2935289:0University of Memphis, Team S1-G8, Willis Fall 2019crwdne2935289:0
UM-WILLIS-F19S1G8
Hey! Thanks a lot for this guide. There's nothing like this on the internet.
Unfortunately though, the issue I'm trying to fix with my LP60 is that of a fuse replacement. One day I'd plugged in my American model without using a voltage converter and I ruined. So could you please help me out? I've opened the thing but I can't seem to spot the fuse. Any guidance would be appreciated.
Thanks
Autameshon - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 23
crwdns2936753:030crwdne2936753:0 112
crwdns2942667:0crwdne2942667:0 7,460
