Asus Zenfone 4 Max Charging Port Replacement
  1. Asus Zenfone 4 Max Charging Port Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Zenfone 4 Max Charging Port Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a removable head screwdriver and a T3 bit, begin by removing the two screws located on either side of the charging port.
    A T3 FEELS too small and a T4 IS too big,the T3 sits in the screw but when I turn it,it strips.
    Sir Frank Macias - crwdns2934203:0crwdne2934203:0
    préciser de retirer le tiroir de la carte sim
    SKRAF Durand - crwdns2934203:0crwdne2934203:0
  2. Asus Zenfone 4 Max Charging Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently wedge the opening tool between the phone and the back casing.
    • Move the opening tool up and down to pry the back off of the device.
    Esa parte tiene dos tornillos adicionales
    Fabian Mendoza - crwdns2934203:0crwdne2934203:0
  3. Asus Zenfone 4 Max Charging Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus Zenfone 4 Max Charging Port Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus Zenfone 4 Max Charging Port Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once the back has been removed, you will need to unscrew the four screws on the bottom panel with an AT3 bit.
  4. Asus Zenfone 4 Max Charging Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the bottom panel.
  5. Asus Zenfone 4 Max Charging Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Zenfone 4 Max Charging Port Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Wedge an opening tool between the battery and phone.
    • Gently pry the battery out of the device.
    • You can move the opening on either side of the battery as well as the bottom to aid in removal.
  6. Asus Zenfone 4 Max Charging Port Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery and replace it with the new battery.
    why do you need to replace the battery with a new one after removing it? Is this step because you wanted new batteries or is it a requirement?
    Merlita Oscares - crwdns2934203:0crwdne2934203:0
  7. Asus Zenfone 4 Max Charging Port Replacement, Charging Port: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus Zenfone 4 Max Charging Port Replacement, Charging Port: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus Zenfone 4 Max Charging Port Replacement, Charging Port: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once the battery has been removed, gently wedge the metal spudger beneath the green panel.
    • Lift the panel along with the charging port out the device and replace with the new charging port.
    What do you call the plastic wrapped around the usb port?
    hanspramirez - crwdns2934203:0crwdne2934203:0
    Just completed the guide, three things to note:
    1) You don’t need to remove the battery if you are just changing the charging port board, it just pops out after the screws are out
    2) The rubber around the port just peels off, so if your replacement part didn’t come with it you can just move it over
    3) Remove the SD/SIM card tray before trying to disassemble the phone, or you will bust yours up like I did
    IHOP007 - crwdns2934203:0crwdne2934203:0
Maegan West
crwdns2935283:010/02/18crwdne2935283:0
839 crwdns2915208:0crwdne2915208:0
Sam Houston State, Team S11-G6, Blackburne Fall 2018 crwdns2935289:0Sam Houston State, Team S11-G6, Blackburne Fall 2018crwdne2935289:0
SHSU-BLACKBURNE-F18S11G6
repair microfone asus zenfone 4 selfie pro please
John Wesley - crwdns2934203:0crwdne2934203:0
I have managed to replace the charging port but now it shows Charging Port Temperatures Abnormalities Reminder which is loud and annoying to see every time. I also see that one of my sensors in the cpu-z program (thermal sensor pa_therm0) hitting a constant 75-84 degree centigrade and another sensor (chg_temp) hitting 65 constantly. Any help in regards to this manner?
Max Orwell - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 3,368
