Asus ZenWatch 2 Battery Replacement
Moriah
crwdns2944107:0crwdnd2944107:0Moriahcrwdnd2944107:0crwdnd2944107:0crwdnd2944107:02crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Yan 7, 2018crwdne2944111:0
crwdns2931287:02crwdne2931287:0
crwdns2937799:0crwdne2937799:0
crwdns2942287:0crwdne2942287:0
The following guide is a step by step process for removing and replacing the battery on an Asus ZenWatch 2. Battery replacement may become necessary if there are issues with battery longevity and charging. Outside of a basic tool kit, no special requirements are needed to successfully replace the ZenWatch 2 Battery
crwdns2944105:0crwdne2944105:0
  1. Asus ZenWatch 2 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ZenWatch 2 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ZenWatch 2 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four 3.5mm screws to detach the case using the T5 screwdriver.
  2. Asus ZenWatch 2 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ZenWatch 2 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the spudger under the battery and lift to remove.
    my zenwatch 2 is all together different it has a plug on top and a piece of metal hooked to the back of battery that looks like it is made on the watch
    glrichy - crwdns2934203:0crwdne2934203:0
crwdns2935229:015crwdne2935229:0
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
Moriah
crwdns2935283:002/20/17crwdne2935283:0
775 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S1-G1, Leahy Spring 2017 crwdns2935289:0USF Tampa, Team S1-G1, Leahy Spring 2017crwdne2935289:0
USFT-LEAHY-S17S1G1
crwdns2947412:013crwdne2947412:0
Where do you get the battery?
Mark Miser - crwdns2934203:0crwdne2934203:0
Sir,
I own Zenwatch 2 and it is just 14 months old. I left it uncharged for months. Now it is not at all charging. In Service Centre, they said Asus did not send any replacement spares even to test what was wrong.
I am from Mumbai, India. Where can i purchase replacement Battery so that i can try? Please help me sir.
Vijaykumar S
Mumbai
vijai kumar - crwdns2934203:0crwdne2934203:0
Hello I have ZenWatch 2 Battery WI502Q-SL-BD need help looking Replacement Battery
Angel Alfredo Grant - crwdns2934203:0crwdne2934203:0
i used non original battery, link here. Compare here.
4spam - crwdns2934203:0crwdne2934203:0
Need soldering? I see it didn't have the connector.
Tendou -
i bought this battery as i belevied it to be compatible - but unfortunately the 2 contacts on the battery are not the same spacing as the original battery
anyone have any experience of swapping the circuit board of the contact between the 2 batteries? i feel this may be my only option of reusing my watch as this is the only manufacturer i have been able to locate :(
robert - crwdns2934203:0crwdne2934203:0
I’ve replaced the battery with an aftermarket one, but now I’ve attached the charging cable and it just buzzes every 2 seconds. No charging progress, no boot screen. I can’t find any mention of this anywhere, but my guess is it doesn’t detect the battery. Anyone see this before? I might have to open it up again and reseat the battery, and those tiny T5 screws are a pain — the worst part was getting them back in, they kept getting attracted by the magnetic charger!
Max - crwdns2934203:0crwdne2934203:0
Never mind, the watch made the same buzzing pattern when I left the battery out and connected the charging cable. It looks like the contacts are spaced slightly differently, like robert described. I’m returning it for a refund, and I’ll try another one.
My zenwatch is 3 years old, roughly.
When I bought the replacement battery, it too did not line up the contacts well either,
I held up the battery in the cover to the main housing of the watch and noticed how much the contacts were misaligned. I bent the posts slightly, GENTLY, and put the cover back on.
While I wouldn't recommend this, it does work.
I was ready to buy a different watch if I snapped a post, but got lucky.
I just hope this battery holds a charge better. I was getting about four hours of life from the original.
sykmot - crwdns2934203:0crwdne2934203:0
Update: the battery I used is the same as robert above. Here’s an amazon link for it:
https://www.amazon.com/dp/B07N7515XD/ref...
the battery has been giving me about 48 hours of use time.
sykmot -
Donde comprar batería para reloj Asus ZenWatch2 model:WI501Q
Jesús Duesca - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 35
crwdns2942667:0crwdne2942667:0 18,115
