Asus ZenFone 5 Touch Sensor Replacement
Nathan Foster
crwdns2944107:0crwdnd2944107:0Nathan Fostercrwdnd2944107:0crwdnd2944107:0crwdnd2944107:02crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Mha 19, 2019crwdne2944111:0
crwdns2931287:045crwdne2931287:0
crwdns2937801:0crwdne2937801:0
crwdns2942287:0crwdne2942287:0
The touch sensor on the ZenFone 5 is located on the back of the phone. Since it is used every time the phone is starting up, it is used very frequently and, since it comes into direct contact with the user very often, can run into issues with relative ease. The touch sensor will need to be replaced if it is not reading a fingerprint or is simply not working in the proper way.
This guide misses a step in disconnecting the touch sensor from the motherboard. If you do not reconnect the press fit connector for the fingerprint sensor during reassembly, it will not function.
crwdns2944105:0crwdne2944105:0
  1. Asus ZenFone 5 Touch Sensor Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat up the iOpener in the microwave for 30 seconds.
    • Caution: when the iOpener is heated up, hold it by the sides to prevent bodily harm.
    Can you condense this step a bit? (e.g., Heat the iOpener in the microwave”)
    Alex Watkins - crwdns2934203:0crwdne2934203:0
  2. Asus ZenFone 5 Touch Sensor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the iOpener on the side of the phone until the iOpener gets cool (approximately 10-15 minutes).
    • Reheat the iOpener and reapply it to the other side of the phone.
  3. Asus ZenFone 5 Touch Sensor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ZenFone 5 Touch Sensor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently slide the jimmy along the edges of the phone to break the adhesive.
    • Use opening picks and the opening tool to pry the back cover off.
    • The use of metal tools as shown in the photos is potentially dangerous as the battery is exposed along the edges of the case and risk of puncture is high. Choose an ESD safe tool instead.
    • There are 6 different tabs on each side of the phone that might take force to get apart.
    • Repeat the heating and prying process until the back cover can be fully removed.
    The tools don’t need to be capitalized, aside from the iOpener. Make sure to check throughout for this issue.
  4. Asus ZenFone 5 Touch Sensor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ZenFone 5 Touch Sensor Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the #00 phillips head to take out the six phillips #00 3.175mm screws on the top cover plate.
    • Use the spudger to release the clasps along the edge of the top plate.
    Per feedback, consider swapping for the nylon spudger, rather than the metal one.
  5. Asus ZenFone 5 Touch Sensor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the press fit connector located near the upper right corner of the battery to disengage the battery from the motherboard.
    My motherbord is shot and don’t open my phone halp me
    Amit Saha - crwdns2934203:0crwdne2934203:0
  6. Asus ZenFone 5 Touch Sensor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ZenFone 5 Touch Sensor Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the same screwdriver to remove the five phillips #00 3.96mm screws along the bottom plate.
    • Use the spudger to pry the bottom plate off.
  7. Asus ZenFone 5 Touch Sensor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ZenFone 5 Touch Sensor Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull on the two black tabs on the bottom of the battery until the battery is released.
    • Gently pull the battery out of its socket.
  8. Asus ZenFone 5 Touch Sensor Replacement, Touch Sensor: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ZenFone 5 Touch Sensor Replacement, Touch Sensor: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • On the back shell of the phone, push with pressure on the touch sensor until it pops out.
    Can you condense these steps?
Nathan Foster
crwdns2935283:007/08/19crwdne2935283:0
612 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S3-G27, Watkins Summer 2019 crwdns2935289:0Embry-Riddle Aeronautical University, Team S3-G27, Watkins Summer 2019crwdne2935289:0
ERAU-WATKINS-SU19S3G27
I might replace the introduction picture in this guide for one that doesn’t have the background missing on the right side.
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 335
