Asus ZenBook UX330U Battery Replacement
  1. Asus ZenBook UX330U Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ZenBook UX330U Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ZenBook UX330U Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before starting any device dissasembly, please put on the anti-static bracelet provided by iFixit. Make sure the metal part of the bracelet is touching your skin.
    • Remove the alligator clip at the end of the bracelet by simply pulling it off, to reveal the bullet connector.
    • Insert the bullet connector into the ground port of an outlet.
    • Make sure to keep the bracelet on at all times while disassembling your device, to prevent ESD to the components.
  2. Asus ZenBook UX330U Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ZenBook UX330U Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Power off the device and make sure it is physically unplugged before starting any disassembly procedures.
    • Remove the eight 3.1 mm screws using the T5 Torx screwdriver.
    • Remove the longer 5.1 mm screw using the T5 Torx screwdriver.
    Is there an option without the blurry hand here?
    Alex Watkins - crwdns2934203:0crwdne2934203:0
  3. Asus ZenBook UX330U Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ZenBook UX330U Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ZenBook UX330U Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Jimmy or a spudger to pry off the two rubber feet that are closest to the hinge.
    • Unscrew the two 5.6mm screws that were underneath the rubber feet using the Philips #0 screwdriver bit.
    • The rubber feet may be difficult to remove. Do not hesitate to use more force to remove the feet, if necessary.
  4. Asus ZenBook UX330U Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ZenBook UX330U Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press the suction handle on the center of the back cover, and gently lift up.
    • You may need to wiggle the back cover as you lift it in order to take it off easily.
    Consider changing to a caution.
  5. Asus ZenBook UX330U Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ZenBook UX330U Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the six 3.7mm screws using the Philips #0 screwdriver bit.
    • Be extra cautious when handling the battery. If the battery looks swollen or damaged, consult this guide.
    Why do you need to remove the battery? You can see the SSD just above the left of the battery.
    You can skip pass step 5 and go to 10, or I am missing something?
    Camilo Fernández Campbell - crwdns2934203:0crwdne2934203:0
  6. Asus ZenBook UX330U Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ZenBook UX330U Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ZenBook UX330U Battery Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four 2.8mm screws from the motherboard ribbon connector using the Philips #0 screwdriver bit.
    • You may have to pull back the black tape located on the bottom right motherboard connector screw. This tape is not necessary for the functionality of the device and can be discarded if necessary.
  7. Asus ZenBook UX330U Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ZenBook UX330U Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ZenBook UX330U Battery Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the motherboard ribbon connector by pulling up on the metal ends with the blunt nose tweezers.
    • You may have to hold down the black tape in order to be able to lift up the connector.
    • To reconnect the motherboard ribbon, simply press the ends of the ribbon on top of the connector. This should require minimal force.
    Great use of special bullets here!
  8. Asus ZenBook UX330U Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ZenBook UX330U Battery Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ZenBook UX330U Battery Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull back the silver battery connector lock with the blunt nose tweezers. This should slide back and should require minimal force.
    • Lift the battery connector vertically using the blunt nose tweezers to remove it from the socket.
    I think you mis-identified the tool here—this looks like tweezers.
  9. Asus ZenBook UX330U Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ZenBook UX330U Battery Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift the battery out of the chassis of the device.
    • Make sure that you do not bend the battery.
For optimal performance, after completing this guide, calibrate your newly installed battery.
crwdns2935229:023crwdne2935229:0
Hasan Akpunar
crwdns2935283:009/20/19crwdne2935283:0
1.454 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S1-G111, Watkins Fall 2019 crwdns2935289:0Embry-Riddle Aeronautical University, Team S1-G111, Watkins Fall 2019crwdne2935289:0
ERAU-WATKINS-F19S1G111
crwdns2947412:019crwdne2947412:0
It would be nice if you mentioned the model of battery the Asus UX330 uses, even of you don’t carry it.
Other than that, great instructions. I’ve ordered tools from you folks and would have ordered the battery if you stocked it.
My wife can hardly wait for me to fix her computer!
Thanks!
Mike
mavery - crwdns2934203:0crwdne2934203:0
Glad the guide was helpful! We (students) did this project as part of a course for our university and compiled all the information ourselves. I don’t remember if we ever found a part number for the battery, which would explain why one wasn’t provided in the guide.
Scott Hansard -
The battery model number is C31N1602
dunxd -
Your instructions made the battery replacement as smooth as silk! I really hate getting into laptops, but you made it (almost) painless.
The problems were, as usual, my big hands and my aging eyes.
Thanks,
Mike
I was pleasantly surprised at how easy the battery replacement turned out to be, partly due to the design of the ASUS UX330, but also due to the excellent repair guide. Thanks!
Michael Goss - crwdns2934203:0crwdne2934203:0
Glad it helped!
Scott Hansard -
I must be a klutz. I attempted this procedure, but when finished the laptop booted but has very dim display and the network adapter didn’t stay powered up. So, I took things apart again and tried to put it back together more solidly, and then the network came back, but the display is still quite dim. I suspect I made a poor connection at the motherboard bridge, but I don’t know how to fix it. (I would not expect a new, but bad, battery would dim the laptop when on power, right?
Ted Wobber - crwdns2934203:0crwdne2934203:0
Hey there, I’m one of the students that compiled this guide. First of all, I’d suggest checking your brightness settings in Windows, as it may have reset when all power was removed from the laptop. If your brightness setting is maxed out on the computer, it is possible that the backlight ribbon cable got unplugged, in which case you’d have to take it apart again and look for that specific connector.
Scott Hansard -
Thank you for a concise and accurate guide. The pictures were clear and the circles and arrows helped locate all the screws, even that one next to the battery connector. Total time was about half an hour because I also did some cleaning to get rid of about three years worth of gunk.
The battery model number on my original is C31N1602. Rated at 11.55 V 57Wh, min 4800 Ah. Hope that helps anyone. I bought a replacement for about $50.
Mark B - crwdns2934203:0crwdne2934203:0
Hi Mark,
Thank you for the detail of the model.
Where did you buy the replacement battery?
Kind regards
Clem
tranquilledusoir -
I used this guide to replace the battery but now have a very strange problem. I replaced the battery without a problem, reconnected everything in the reverse order and screwed the case back together. When I plugged in the power cable, the the power light on the side, the on on/off button on the keyboard , F2 and Caps Lock all lit up. The laptop did nothing. I took everything apart again and carefully repeated all steps again with the same result. I even put back in the old battery and still the same result. In much trial and error I found out that everything works fine with the new battery (the machine starts properly and the battery starts charging as long as I do not reassemble the case. As soon as I put just one screw in the the rear cover and tighten it I get the problem.
Richard Allen - crwdns2934203:0crwdne2934203:0
After changing my battery if no problem. (thank you). Zenbook cannot find network adapter period. Help!
Dorothy Simmons - crwdns2934203:0crwdne2934203:0
Thank you for this well detailed guide. It helped a lot. Published from an Asus Zenbook UX330UA with a brand new battery!
Bruno Jette - crwdns2934203:0crwdne2934203:0
Unfortunately, I bricked my computer trying this repair, and do not recommend others try it. Issues I encountered:
1) The rubber feet at the bottom are *incredibly* well glued on. I cut myself on the recommended Jimmy. Another guide recommended using a flatheaded screwdriver instead, and I found that easier to brace against my finger.
2) The battery itself didn’t quite fit correctly. While the same part number, it was not the exact same, with a slightly different battery connector cable (which couldn’t be latched down in the computer).
3) My kit shipped with *angled* tweezers instead of *blunt* ones. I believe attempting to use the angled ones where the blunt ones were called for, combined with the issues I had with fit, may have damaged some components
I found both the motherboard ribbon and the battery connector very difficult to try to secure with the new battery in, and after giving up on that and going back to the old battery, my computer won’t boot at all. I hope others have more success than I did.
Thomas Niemasik - crwdns2934203:0crwdne2934203:0
Just had a very similar experience with trying to use the Asus UX330UA fix kit. The rubber feet were glued on tightly, so using a screwdriver helped. Blunt tweezers are indeed not included in the kit - I went and grabbed tweezers that I owned, but that is something to consider. The battery connector cable was too long, so I will have to make a return, making my efforts useless. It is more worth your time, effort, and money taking your laptop to an Asus service center.
Amal Saeed -
If I was doing this job I would disconnect the battery first before the mother board cable. What do you think?
mike - crwdns2934203:0crwdne2934203:0
probably should update this line in Step 1: "Before starting any device disassembly, please put on the anti-static bracelet provided by iFixit. Make sure the metal part of the bracelet is touching your skin."
As my 'kit' of Battery and 'Kit' did not include the anti-static bracelet noted in this step.
Concierge - crwdns2934203:0crwdne2934203:0
Step 8: 'Pull back the silver battery connector lock with the blunt nose tweezers.' The action is not obvious as 'back' is relative to where you are sitting and the orientation. Back in this case is ?? The back of the computer? Towards the rear of the computer? Suggest something of the sort: Slide the metal 'lock' away from the white connector. The 'lock' is sliding horizontally away from you and away from the white connector as seen in the first image.
The iFixit battery that I received was physically the same size as the original, but the plastic tabs that align the battery and have the screw holes and alignment holes, were off by about 1 mm left to right - too narrow. This made the 're-assembly' tricky.
In general, this step-by-step guide is very good. That's why I buy most of my repair parts from iFixit; clear instructions and guides.
The 'kit' that one can by with the battery does not have the tools outlined in this article. For instance, there are no 'blunt nose tweezers,' but rather sharp nose tweezers.
Small differences, but significant when a sharp nose tweezers could damage something when a blunt nose tweezer is the right tool.
The kit is awesome with its labeling and great 'top' to hold the parts organized by sector. Allowed me to keep the one 5.1mm screw in step 2 isolated and very easy to find. I have all these tools but having them in an organized kit is icing on the cake. Highly recommend it.
crwdns2936753:07crwdne2936753:0 49
crwdns2936753:030crwdne2936753:0 215
crwdns2942667:0crwdne2942667:0 21,236
