Asus X751L Battery Replacement
crwdns2942287:0crwdne2942287:0This guide will walk you through the process of replacing a broken or faulty battery on the Asus X751L.
crwdns2942269:0crwdne2942269:0
crwdns2942337:0crwdne2942337:0
crwdns2944105:0crwdne2944105:0
With the screen closed, place your laptop upside-down with the front facing you.
Remove the six 14.6mm Phillips #00 screws.
Remove the four 6.6mm Phillips #00 screws.
Flip the laptop over and open the lid.
Pry around the edges of the laptop base using the plastic opening tool.
Carefully lift the keyboard up.
Disconnect the two ZIF connectors from the motherboard using your fingernail to lift the cream-colored tab.
Remove the two 6.6mm Phillips #00 screws holding the battery in place.
Lift the battery from the cable-side to maneuver it around the plastic clips.
Using your finger nails, gently push the battery cable out of the connector on the motherboard.
Once the cable is disconnected, you can remove the battery.
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0crwdns2947412:06crwdne2947412:0
Very nice, thank you !
very nice, thank you !
Took me awhile to figure out how to get the cables back. Other than that, good insturctions.
Your instructions were easy to follow. Thank you!!!
very helpful
What do the yellow and white wires do ?
