ASUS X54C X54H X54HR - How to remove and replace the keyboard.
crwdns2936621:0crwdne2936621:0
Disconnect the charger and switch off the laptop.
Two keys keep locked battery.
The Keyboard is held by 5x locking clips.
Use a tool with with a thin tip and lift slightly the KB from the left side.
Unlock clips one by one.
Disconnect the KB ribbon cable.
crwdns2935229:09crwdne2935229:0
Thanks for the detailed vid! What are the materials used at 07:00-08:00 to clean and replace the paste? Specifically what's in the spray bottle and the syringe
Hello,
To clean the thermal paste, the author used a soft toothbrush (probably with isopropyllic alcohol).
The syringe contains a non-conductive thermal paste.
You can replace the toothbrush by cell polyurethane foam swabs and isopropilic alcohol to remove the old thermal paste if you want.
This is a laptop with a CPU that doesn't heat too much, so you can replace the original thermal paste by any non conductive thermal paste made to be used in computers it will be fine.
Brendan -
