Asus VivoTab Smart Battery Replacement
  1. Asus VivoTab Smart Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus VivoTab Smart Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus VivoTab Smart Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Power off the device before you begin disassembly.
    • Place the device face down on a flat surface.
    • Remove the back panel with the plastic opening tool by sliding the tool around the edge of the panel.
  2. Asus VivoTab Smart Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus VivoTab Smart Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus VivoTab Smart Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the tape covering the 3 ribbons by peeling it off with your hands or with the tweezers.
    • Carefully detach the ribbons from the device's motherboard by pulling outward using tweezers.
  3. Asus VivoTab Smart Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus VivoTab Smart Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus VivoTab Smart Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The Philips #00 Screwdriver listed in the recommended tools will fit all the screws.
    • Remove the tape covering the areas marked by the black arrows
    • Remove two 3.7 mm Phillips #00 screws
    • Remove eleven 2.7 mm Phillips #00 screws
  4. Asus VivoTab Smart Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus VivoTab Smart Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Be careful not to damage the speaker wire.
    • Gently unplug the speaker from the motherboard by grabbing the wire near the plastic white plug with tweezers and gently pulling.
    • Lift up on the speaker with your fingers to remove it.
  5. Asus VivoTab Smart Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the battery pressure plate off of the motherboard.
  6. Asus VivoTab Smart Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus VivoTab Smart Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to separate the battery tray from the device
    • Lift the battery tray from the device using your hands.
  7. Asus VivoTab Smart Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The battery is secured to the tray by a strong adhesive. Take care not to bend the tray when removing the battery.
    • Detach the battery from the tray by pulling the battery up from the tray with your hands.
    • If it is very difficult to lift the battery from the tray, you can use a blow dryer to heat the back side of the tray. This will weaken the adhesive and make it easier to remove.
Zach Hatten
crwdns2935283:010/06/16crwdne2935283:0
563 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 2-4, Sullivan Fall 2016 crwdns2935289:0USF Tampa, Team 2-4, Sullivan Fall 2016crwdne2935289:0
USFT-SULLIVAN-F16S2G4
Hi
So where is the next step ?!
Albert einstein - crwdns2934203:0crwdne2934203:0
Hi
Please answer to me. This is so
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 3,389
