Asus VivoBook X540N RAM Replacement
  1. Asus VivoBook X540N RAM Replacement, RAM: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Power down your device.
    • Unplug the charger.
  2. Asus VivoBook X540N RAM Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following screws that secure the lower case with a Phillips #00 screwdriver:
    • Four 0.5 mm screws
    • Five 0.9mm screws
    • One 1 cm screw
    • Flip the laptop upright.
    • Insert a pry tool in the seam between the lower case and chassis.
    • Pry around the perimeter until the lower case releases.
    • If it is not easily coming apart, it is normal to add a little bit of force to pry it open.
  3. Asus VivoBook X540N RAM Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus VivoBook X540N RAM Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus VivoBook X540N RAM Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To remove, gently push the metal clips on the sides of the RAM module outward. This will cause it to pop up slightly.
    • Carefully pull the RAM module out at an angle.
    • It should come out easily without the need for much force.
    • Gently insert the new RAM module into the slot at an angle and pressing it down until the metal clips on the sides click into place.
To reassemble your device, follow these instructions in reverse order
Saad Jamal
crwdns2935283:009/14/23crwdne2935283:0
121 crwdns2915208:0crwdne2915208:0
York University, Team B-21, Woodhouse Fall 2023 crwdns2935289:0York University, Team B-21, Woodhouse Fall 2023crwdne2935289:0
YORK-WOODHOUSE-F23SBG21
i have a sonic master asus pc with a motherboard model is X540NA 1.0 i have 4gb ram DDR3 how i can upgrade, pls respond quickly i need this
Albert Einstein - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 60
crwdns2942667:0crwdne2942667:0 1,020
