If you need a new battery on your Asus F412DA laptop here is a guide on how to do it.
crwdns2935267:0crwdne2935267:0Anti-Static Wrist Strap$7.95
Start by removing the marked screws
Remove the four 6mm screws
Remove the two 8mm screws
Remove the four 9mm screws
Using a opening tool, pry and lift at the edge of the bottom until you feel it open.
Using a fingernail or spudger move back the retaining clip holding the battery connector in place.
So yeah...I tore off the remaining clip trying to get the connector out. What do I do now?
Put a spudger under the battery connector and twist, the connector should lift off.
Remove the two 5mm screws.
Remove the 4mm screw.
Carefully lift the old battery out of the computer.
To reassemble your device, insert the new battery and follow these instructions in reverse order.
Can I get a link of the RAM 🙏
