Asus TUF Gaming FX505DY Touchpad Replacement
  1. Asus TUF Gaming FX505DY Touchpad Replacement, Motherboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus TUF Gaming FX505DY Touchpad Replacement, Motherboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus TUF Gaming FX505DY Touchpad Replacement, Motherboard: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With a Phillips 0-bit screwdriver, remove eight 5.0 mm screws on the silver brackets
    • With a Phillips 0-bit screwdriver, remove two 5.0 mm screws holding the edge of the fans in place
  2. Asus TUF Gaming FX505DY Touchpad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus TUF Gaming FX505DY Touchpad Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus TUF Gaming FX505DY Touchpad Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently remove all power cables connecting the fans to the motherboard.
    • Once all cables and screws are removed, carefully lift up and remove the fans and heat sink
  3. Asus TUF Gaming FX505DY Touchpad Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus TUF Gaming FX505DY Touchpad Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With a Phillips 0-bit screwdriver, unscrew four 5.0 mm screws.
    • Disconnect the primary connector cable located at the bottom left and carefully remove the module.
  4. Asus TUF Gaming FX505DY Touchpad Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus TUF Gaming FX505DY Touchpad Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus TUF Gaming FX505DY Touchpad Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Removing the ram, push down unto the ram and move the metal locking tabs to the side by lifting upward slightly then moving each to their outside.
    • Pull the ram out toward the angle when the ram is sticking up at an angle when released.
  5. Asus TUF Gaming FX505DY Touchpad Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus TUF Gaming FX505DY Touchpad Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With a Phillips 0-bit screwdriver, unscrew four 5.0 mm top screws holding the hard drive in place.
    • Pinch the top left corner with your finger and slide the harddrive out of its casing.
  6. Asus TUF Gaming FX505DY Touchpad Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus TUF Gaming FX505DY Touchpad Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With a Phillips 0-bit screwdriver, unscrew two 5.0 mm screws holding SSD down to the motherboard on the right side of the board
    • Slide module out of protective casing to remove piece.
  7. Asus TUF Gaming FX505DY Touchpad Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus TUF Gaming FX505DY Touchpad Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus TUF Gaming FX505DY Touchpad Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With a size 0 Phillips screwdriver, unscrew three center 5 mm screws securing the board in place.
    • Carefully lift the board and place in a safe area.
  8. Asus TUF Gaming FX505DY Touchpad Replacement, Touchpad: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus TUF Gaming FX505DY Touchpad Replacement, Touchpad: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus TUF Gaming FX505DY Touchpad Replacement, Touchpad: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With a size 0 Phillips screwdriver, unscrew two 5 mm screws holding the trackpad in place located at the bottom of the trackpad.
    • Carefully unclip the connector base to remove the two touchpad cables.
    • Remove the trackpad by sliding forward and lifting up.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Sebastian Frederick Klincewicz
crwdns2935283:010/04/22crwdne2935283:0
418 crwdns2915208:0crwdne2915208:0
The Citadel Military College of South Carolina, Team 3-19, Eggleston Fall 2022 crwdns2935289:0The Citadel Military College of South Carolina, Team 3-19, Eggleston Fall 2022crwdne2935289:0
CMCSC-EGGLESTON-F22S3G19
crwdns2936753:07crwdne2936753:0 29
crwdns2936753:030crwdne2936753:0 105
crwdns2942667:0crwdne2942667:0 1,532
