Asus ROG G751JL-BSI7T28 Display Assembly Replacement
  1. Asus ROG G751JL-BSI7T28 Display Assembly Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the laptop closed, turn it upside-down so the bottom is facing up toward you.
  2. Asus ROG G751JL-BSI7T28 Display Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ROG G751JL-BSI7T28 Display Assembly Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ROG G751JL-BSI7T28 Display Assembly Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place a spudger into the notch, and pry the small triangular piece away from the laptop.
    • Using a Phillips #00 screwdriver, remove the single 3 mm screw.
    • Place a spudger beneath the back panel and pry it away from the laptop.
  3. Asus ROG G751JL-BSI7T28 Display Assembly Replacement, Display Assembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ROG G751JL-BSI7T28 Display Assembly Replacement, Display Assembly: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove all 5mm Phillips #00 screws from the back cover.
  4. Asus ROG G751JL-BSI7T28 Display Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ROG G751JL-BSI7T28 Display Assembly Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry the disc drive out of the laptop.
  5. Asus ROG G751JL-BSI7T28 Display Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ROG G751JL-BSI7T28 Display Assembly Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ROG G751JL-BSI7T28 Display Assembly Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the laptop and turn it so that the ASUS logo is facing you.
    • Gently lift up the display hinge housing shroud, but don’t pull it completely away yet.
    • Disconnect the RGB light power cable in the shroud, now the shroud can be put aside.
  6. Asus ROG G751JL-BSI7T28 Display Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ROG G751JL-BSI7T28 Display Assembly Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ROG G751JL-BSI7T28 Display Assembly Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 5mm Phillips #00 screws.
    • Lift up the silver hinge brackets on each side of the laptop.
  7. Asus ROG G751JL-BSI7T28 Display Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ROG G751JL-BSI7T28 Display Assembly Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 5mm Phillips #00 screws from the hinges.
    • Detach the ribbon cable and remove the display assembly from the laptop.
Kristen Gismondi
crwdns2935283:011/12/14crwdne2935283:0
97,505 crwdns2915208:0crwdne2915208:0
crwdns2935297:0255crwdne2935297:0
Staff
crwdns2931471:0120crwdne2931471:0
crwdns2935297:023,076crwdne2935297:0
crwdns2942667:0crwdne2942667:0 450
