Asus ROG G20CB CPU Replacement
  1. Asus ROG G20CB CPU Replacement, Fan: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ROG G20CB CPU Replacement, Fan: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove each of the two 4.6 mm Phillips screws on the top and bottom of the tower.
  2. Asus ROG G20CB CPU Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the front panel to the left and lift gently.
    • There is a cable connecting the panel to the computer. Handle it gently and avoid straining the connected panel.
  3. Asus ROG G20CB CPU Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the cable carefully by pulling gently on both sides of the connector.
  4. Asus ROG G20CB CPU Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five 4.6 mm Phillips screws holding down the fan tray and then pull the fan tray out of the system.
    • The fans are connected by a thin cable, be gentle when removing tray.
  5. Asus ROG G20CB CPU Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully unplug the two fan cables from the motherboard by pulling straight up from the base of the connector.
  6. Asus ROG G20CB CPU Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six 4.6 mm Phillips screws connecting the fans to the fan tray.
  7. Asus ROG G20CB CPU Replacement, CPU Cooler: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 4.6 mm Phillips screw that secures the optical drive.
  8. Asus ROG G20CB CPU Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push the optical drive out of the chassis.
  9. Asus ROG G20CB CPU Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull back the tape on the heat sink and use a long-neck Phillips screwdriver to remove the four screws securing the heat sink.
    • There is a number next to each screw, when taking the cooler off, loosen in descending order (4-3-2-1). When installing a cooler, tighten in ascending order.
  10. Asus ROG G20CB CPU Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 4.6 mm Phillips screw from the heatsink at the top of the case.
    • Lift the CPU cooler out of the system.
    • Be sure to apply fresh thermal paste before reinstalling a cooler.
  11. Asus ROG G20CB CPU Replacement, CPU: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the CPU socket retention arm next to the processor.
    • Push the arm down and out, then lift it upward to release the CPU cover.
  12. Asus ROG G20CB CPU Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the CPU straight out of the socket.
    • Handle the CPU by its edges. Do not touch the bottom pins or contacts to avoid damage.
  13. Asus ROG G20CB CPU Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reassembly tip: When installing a new CPU make sure to align the gold triangle with the white circle on the motherboard.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Kimber-Starr
crwdns2935283:003/21/25crwdne2935283:0
319 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 3-3, Botvin Spring 2025 crwdns2935289:0UMass Dartmouth, Team 3-3, Botvin Spring 2025crwdne2935289:0
UMASSD-BOTVIN-S25S3G3
crwdns2942667:0crwdne2942667:0 147
