Asus ROG G20CB RAM Replacement
    1. Asus ROG G20CB  RAM Replacement, Fan: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ROG G20CB  RAM Replacement, Fan: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove each of the two 4.6 mm Phillips screws on the top and bottom of the tower.
    2. Asus ROG G20CB  RAM Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Slide the front panel to the left and lift gently.
      • There is a cable connecting the panel to the computer. Handle it gently and avoid straining the connected panel.
    3. Asus ROG G20CB  RAM Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Disconnect the cable carefully by pulling gently on both sides of the connector.
    4. Asus ROG G20CB  RAM Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the five 4.6 mm Phillips screws holding down the fan tray and then pull the fan tray out of the system.
      • The fans are connected by a thin cable, be gentle when removing tray.
    5. Asus ROG G20CB  RAM Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully unplug the two fan cables from the motherboard by pulling straight up from the base of the connector.
    6. Asus ROG G20CB  RAM Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the six 4.6 mm Phillips screws connecting the fans to the fan tray.
    1. Asus ROG G20CB  RAM Replacement, CPU Cooler: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the 4.6 mm Phillips screw that secures the optical drive.
    2. Asus ROG G20CB  RAM Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Push the optical drive out of the chassis.
    3. Asus ROG G20CB  RAM Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pull back the tape on the heat sink and use a long-neck Phillips screwdriver to remove the four screws securing the heat sink.
      • There is a number next to each screw, when taking the cooler off, loosen in descending order (4-3-2-1). When installing a cooler, tighten in ascending order.
    4. Asus ROG G20CB  RAM Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the 4.6 mm Phillips screw from the heatsink at the top of the case.
      • Lift the CPU cooler out of the system.
      • Be sure to apply fresh thermal paste before reinstalling a cooler.
    1. Asus ROG G20CB  RAM Replacement, RAM: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Gently push outward on the two retaining clips on either side of the RAM stick.
    2. Asus ROG G20CB  RAM Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • The RAM module should pop up at an angle.
      • Pull the RAM stick out carefully by grasping it by the edges.
      • Avoid touching gold contacts.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Kimber-Starr
crwdns2935283:003/21/25crwdne2935283:0
361 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 3-3, Botvin Spring 2025 crwdns2935289:0UMass Dartmouth, Team 3-3, Botvin Spring 2025crwdne2935289:0
UMASSD-BOTVIN-S25S3G3
crwdns2936753:030crwdne2936753:0 110
crwdns2942667:0crwdne2942667:0 883
