Asus ROG Ally Triggers Replacement
  1. Asus ROG Ally Triggers Replacement, Prepare your device for disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ROG Ally Triggers Replacement, Prepare your device for disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ROG Ally Triggers Replacement, Prepare your device for disassembly: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Let your device's battery drain below 25% before starting this repair—a charged lithium‑ion battery may catch fire if damaged.
    • Completely power off your device and unplug all cables.
    • Consider laying your device on a soft cloth to prevent scratching or damaging the screen during your repair.
  2. Asus ROG Ally Triggers Replacement, Unfasten the back cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ROG Ally Triggers Replacement, Unfasten the back cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    FixMat
    $31.41
    • Use a Phillips #0 screwdriver to remove the five 17.2 mm‑long screws securing the top edge and bottom corners of the back cover.
    • Use a Phillips #0 screwdriver to fully loosen the remaining captive screw at the center of the bottom edge. This should create a small gap between the back cover and chassis.
    • Don't try to remove this screw.
  3. Asus ROG Ally Triggers Replacement, Insert an opening pick: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ROG Ally Triggers Replacement, Insert an opening pick: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ROG Ally Triggers Replacement, Insert an opening pick: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the flat edge of an opening pick between the bottom edge of the back cover and chassis, near the captive screw.
    • Angle the pick upward and push it under the back cover.
  4. Asus ROG Ally Triggers Replacement, Release the back cover's clips: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ROG Ally Triggers Replacement, Release the back cover's clips: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ROG Ally Triggers Replacement, Release the back cover's clips: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Plastic clips secure the perimeter of the back cover. You should feel and hear them release during this step.
    • Slide the opening pick along the bottom edge and around the corners of the back cover to release the clips securing it.
    • Keep the pick at an upward angle under the back cover to help release the clips.
  5. Asus ROG Ally Triggers Replacement, Remove the back cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ROG Ally Triggers Replacement, Remove the back cover: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ROG Ally Triggers Replacement, Remove the back cover: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the bottom edge of the back cover off the chassis to release the remaining clips.
    • Remove the back cover.
    • During reassembly, lay the back cover onto your device and firmly push down around the perimeter to engage the clips.
  6. Asus ROG Ally Triggers Replacement, Unfasten the triggers: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ROG Ally Triggers Replacement, Unfasten the triggers: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ROG Ally Triggers Replacement, Unfasten the triggers: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the two 3.4 mm‑long screws securing each trigger (four screws total).
  7. Asus ROG Ally Triggers Replacement, Remove the triggers: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ROG Ally Triggers Replacement, Remove the triggers: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ROG Ally Triggers Replacement, Remove the triggers: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the triggers straight up and out of their recesses to remove them.
  8. Asus ROG Ally Triggers Replacement, Trigger installation: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • During reassembly:
    • Compress the trigger and firmly push it into place on the chassis so the cutouts on the hinge go over their alignment posts. The trigger should stay in place.
    • Keep the trigger compressed and install the two screws.
    • Test the trigger before continuing reassembly. If it's not working properly, remove the trigger and make sure it's properly aligned on the hinge.
  9. Asus ROG Ally Triggers Replacement, Unclip the triggers: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ROG Ally Triggers Replacement, Unclip the triggers: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ROG Ally Triggers Replacement, Unclip the triggers: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Two plastic clips secure each trigger to its hinge.
    • Carefully pull the trigger away from the hinge one side at a time to detach both clips.
    • To install a trigger on its hinge:
    • Make sure the middle section of the spring is looped over the tab on the hinge with the bent ends facing down.
    • With the trigger on the opposite side of the hinge screw-holes, clip it into place so the coiled parts of the spring are between the trigger clips.
    • The trigger should compress and spring back when you press it down.
Spencer Day
crwdns2935283:009/14/22crwdne2935283:0
119.190 crwdns2915208:0crwdne2915208:0
crwdns2935297:0838crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021.729crwdne2935297:0
Ou trouvons nous les pièces de remplacement
Alien TOYS AlienTOYS - crwdns2934203:0crwdne2934203:0
Is this the same part as the Ally X?
MightyCreator - crwdns2934203:0crwdne2934203:0
So there's no wires going to the trigger assembly, how is the trigger depression being detected?? It's the joystick assembly detecting it somehow, right?? I replaced the stick with a hall effect and now the trigger isn't working on that same side.
Eric Birecki - crwdns2934203:0crwdne2934203:0
There is electromagnetic interference between the trigger and joystick. You need to use some shielding paper.
Dusán Kricskovics -
crwdns2936751:024crwdne2936751:0 17
crwdns2936753:07crwdne2936753:0 109
crwdns2936753:030crwdne2936753:0 415
crwdns2942667:0crwdne2942667:0 5,177
