Asus ROG Ally SSD Replacement
  1. Asus ROG Ally SSD Replacement, Prepare your device for disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ROG Ally SSD Replacement, Prepare your device for disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ROG Ally SSD Replacement, Prepare your device for disassembly: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Let your device's battery drain below 25% before starting this repair—a charged lithium‑ion battery may catch fire if damaged.
    • Completely power off your device and unplug all cables.
    • Consider laying your device on a soft cloth to prevent scratching or damaging the screen during your repair.
  2. Asus ROG Ally SSD Replacement, Unfasten the back cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ROG Ally SSD Replacement, Unfasten the back cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    FixMat
    $36.95
    • Use a Phillips #0 screwdriver to remove the five 17.2 mm‑long screws securing the top edge and bottom corners of the back cover.
    • Use a Phillips #0 screwdriver to fully loosen the remaining captive screw at the center of the bottom edge. This should create a small gap between the back cover and chassis.
    • Don't try to remove this screw.
  3. Asus ROG Ally SSD Replacement, Insert an opening pick: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ROG Ally SSD Replacement, Insert an opening pick: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ROG Ally SSD Replacement, Insert an opening pick: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the flat edge of an opening pick between the bottom edge of the back cover and chassis, near the captive screw.
    • Angle the pick upward and push it under the back cover.
  4. Asus ROG Ally SSD Replacement, Release the back cover's clips: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ROG Ally SSD Replacement, Release the back cover's clips: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ROG Ally SSD Replacement, Release the back cover's clips: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Plastic clips secure the perimeter of the back cover. You should feel and hear them release during this step.
    • Slide the opening pick along the bottom edge and around the corners of the back cover to release the clips securing it.
    • Keep the pick at an upward angle under the back cover to help release the clips.
  5. Asus ROG Ally SSD Replacement, Remove the back cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ROG Ally SSD Replacement, Remove the back cover: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ROG Ally SSD Replacement, Remove the back cover: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the bottom edge of the back cover off the chassis to release the remaining clips.
    • Remove the back cover.
    • During reassembly, lay the back cover onto your device and firmly push down around the perimeter to engage the clips.
  6. Asus ROG Ally SSD Replacement, Remove the plastic cover: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ROG Ally SSD Replacement, Remove the plastic cover: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ROG Ally SSD Replacement, Remove the plastic cover: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to peel up and remove the black plastic cover between the fans.
    • Put the cover aside—you'll use it during reassembly.
  7. Asus ROG Ally SSD Replacement, Unlatch the locking bar: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ROG Ally SSD Replacement, Unlatch the locking bar: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ROG Ally SSD Replacement, Unlatch the locking bar: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • A metal locking bar secures the top edge of the battery connector
    • Use the flat end of a spudger to gently push the locking bar away from the connector to unlatch it.
  8. Asus ROG Ally SSD Replacement, Disconnect the battery: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ROG Ally SSD Replacement, Disconnect the battery: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ROG Ally SSD Replacement, Disconnect the battery: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Make sure the locking bar is not covering the battery connector at all, or you may damage the socket and the locking bar.
    • Insert the flat end of a spudger under the center of the battery connector.
    • Lift the connector straight up and out of its socket to disconnect the battery.
    • During reassembly, use your fingers or the flat end of a spudger to firmly push the connector onto its socket until it clicks into place.
  9. Asus ROG Ally SSD Replacement, Unfasten the SSD: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ROG Ally SSD Replacement, Unfasten the SSD: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the 3.4 mm‑long screw securing the SSD.
  10. Asus ROG Ally SSD Replacement, Remove the SSD: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ROG Ally SSD Replacement, Remove the SSD: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If you have trouble removing the SSD, you can remove the battery for easier access.
    • Grip the bottom corners of the SSD and slightly lift until it clears the screw post.
    • Do not lift more than this or you may damage the SSD and its socket.
    • Pull the SSD straight out of its socket and remove it.
  11. Asus ROG Ally SSD Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ROG Ally SSD Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once you've reassembled your device:
    • Plug your device in and turn it on. It should boot into the BIOS menu.
    • Navigate to the Advanced tab and click ASUS Cloud Recovery.
    • Follow the prompts to finish setting up your device.
Spencer Day
crwdns2935283:009/14/22crwdne2935283:0
135.913 crwdns2915208:0crwdne2915208:0
crwdns2935297:0917crwdne2935297:0
Staff
crwdns2935297:023.161crwdne2935297:0
Hi Spencer. Look, I wanted to ask you a question, it turns out that my Asus rog ally is stuck on its home screen, as if it could not boot, I checked everything, disk, motherboard and everything is in order, I imagine the bios menu is broken, you could help me with that?
Sebastian - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 32
crwdns2936753:07crwdne2936753:0 215
crwdns2936753:030crwdne2936753:0 930
crwdns2942667:0crwdne2942667:0 17,960
