You will learn how to replace the motherboard. Review this guide if you are having difficulties with the motherboard. In order to replace the motherboard, you have to remove the battery. Please use our Asus MeMO Pad HD 8 ME180A Battery Replacement Guide to do so prior to starting.
Use a plastic opening tool to separate the back half from the front half.
Pull the back panel away from the device.
crwdns2935267:0crwdne2935267:0Anti-Static Wrist Strap$7.16
Ensure that you are wearing your Anti-Static Wrist Strap.
Lift the white bar on the ZIF connector and pull the metal connector out.
Using your spudger, press down on the two spots shown in order to release the cables.
Ensure that the touchscreen cables are fully disconnected.
Using a PH#0 screwdriver, remove the twelve silver 3.2 mm screws.
Pull the battery out.
Disconnect GPS Antenna cable.
Flip the latch and pull the ribbon cable to disconnect the ZIF connector.
Use a PH#0 screwdriver to unscrew the six 3.0 mm black screws.
Lift the motherboard straight up to remove.
Où je peux avoir une carte mère pour asus memo pad8 me 180
Shouldn’t there be a step to handle the camera?
I would not suggest this to a beginner, quite thankfully I have been just practising my fixing skills, yet I managed to break the lid of the display of the tablet and the tool even with the triangle plastics that hold it opened, it broke and shattered
Lukáš Otáhal - crwdns2934203:0crwdne2934203:0
