Asus L410MA-MH09-CA Keyboard Replacement
  1. Asus L410MA-MH09-CA Keyboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all ten 6 mm Phillips #1 screws that secure the lower case.
    • Insert an opening pick in the gap between the lower case and chassis.
    • Slide the opening pick around the entire perimeter of the laptop until the lower case fully releases.
    • Remove the lower case.
  2. Asus L410MA-MH09-CA Keyboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 4 mm Phillips #1 screws that secure the battery.
  3. Asus L410MA-MH09-CA Keyboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grip the white battery connector and pull it directly out of its battery port.
  4. Asus L410MA-MH09-CA Keyboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the battery out carefully.
  5. Asus L410MA-MH09-CA Keyboard Replacement, Keyboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the screws that secure the hinges.
    • Lift the hinges up and out.
  6. Asus L410MA-MH09-CA Keyboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus L410MA-MH09-CA Keyboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the battery and display connectors.
  7. Asus L410MA-MH09-CA Keyboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus L410MA-MH09-CA Keyboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus L410MA-MH09-CA Keyboard Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four 4 mm Phillips #1 screws that secure the heatsink.
    • Remove the heatsink.
    • Remove the remaining two 4 mm Phillips #1 screws that secure the motherboard.
    • Remove the motherboard.
  8. Asus L410MA-MH09-CA Keyboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to pry around the entire perimeter of the metal bracket until it fully releases.
    • Remove the metal bracket.
  9. Asus L410MA-MH09-CA Keyboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus L410MA-MH09-CA Keyboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully disconnect the wide blue ribbon cable.
    • Remove the keyboard.
Take your e-waste to an R2 or e-Stewards certified recycler.m
Jimmy
crwdns2935283:010/22/24crwdne2935283:0
331 crwdns2915208:0crwdne2915208:0
Gateway, Team 8-2, Gonzalez Fall 2024 crwdns2935289:0Gateway, Team 8-2, Gonzalez Fall 2024crwdne2935289:0
GCC-GONZALEZ-F24S8G2
crwdns2942667:0crwdne2942667:0 225
