Asus K53S -X156V Thermal Paste Replacement
  1. Asus K53S -X156V Thermal Paste Replacement, removing battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus K53S -X156V Thermal Paste Replacement, removing battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus K53S -X156V Thermal Paste Replacement, removing battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • remove battery by sliding the two release buttons to the right position.
    • slide the battery away from the laptop
  2. Asus K53S -X156V Thermal Paste Replacement, removing plastic plate RAM/HDD: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus K53S -X156V Thermal Paste Replacement, removing plastic plate RAM/HDD: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • remove the 2 screws holding the plastic plate , underneath is the RAM/ WiFi and HDD
    • the 2 screws are marked in red. afterwarts slide it away from the laptop
    • keep track of all the screws and parts. make a map or a plan.
  3. Asus K53S -X156V Thermal Paste Replacement, removing RAM: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus K53S -X156V Thermal Paste Replacement, removing RAM: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus K53S -X156V Thermal Paste Replacement, removing RAM: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • click the ram module out of there sockets.
    • push the metal clips away from the module.
  4. Asus K53S -X156V Thermal Paste Replacement, Remove wifi module: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus K53S -X156V Thermal Paste Replacement, Remove wifi module: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • remove the black and white wire.
    • remove the screw.
  5. Asus K53S -X156V Thermal Paste Replacement, removing hard disk: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus K53S -X156V Thermal Paste Replacement, removing hard disk: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus K53S -X156V Thermal Paste Replacement, removing hard disk: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • remove the 4 screws holding the metal frame , holding the hdd to it's place.
    • slide the frame and hard disk away from the case.
  6. Asus K53S -X156V Thermal Paste Replacement, removing keyboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus K53S -X156V Thermal Paste Replacement, removing keyboard: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • click the keyboard loose . There are 5 clips to remove
  7. Asus K53S -X156V Thermal Paste Replacement, keyboard second part: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus K53S -X156V Thermal Paste Replacement, keyboard second part: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus K53S -X156V Thermal Paste Replacement, keyboard second part: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • be carefull with the flat cable from the keyboard.
    • use a spudger to click the connector lid loose.
    • i used the tip of a screwdriver.. but i know what i am doing.. if you are use to work on laptops you can use a screwdriver, if not use a plastic spudger.
  8. Asus K53S -X156V Thermal Paste Replacement, remove DVD bay: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus K53S -X156V Thermal Paste Replacement, remove DVD bay: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus K53S -X156V Thermal Paste Replacement, remove DVD bay: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • remove the screw hidden under the keyboard.
    • slide the dvd bay out.
  9. Asus K53S -X156V Thermal Paste Replacement, removing flat cables: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus K53S -X156V Thermal Paste Replacement, removing flat cables: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus K53S -X156V Thermal Paste Replacement, removing flat cables: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • remove the flat thin cables from there sockets.
    • use a spudger , click the lid upwards and slide the flat cable out.
  10. Asus K53S -X156V Thermal Paste Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus K53S -X156V Thermal Paste Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus K53S -X156V Thermal Paste Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • remove the 6 screws ( m2x6) holding the metal plate to the case.
  11. Asus K53S -X156V Thermal Paste Replacement, remove screws on the bottom plate: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus K53S -X156V Thermal Paste Replacement, remove screws on the bottom plate: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus K53S -X156V Thermal Paste Replacement, remove screws on the bottom plate: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • remove screws as shown in pictures.
    7 screw to remove in last picture
    smiled s - crwdns2934203:0crwdne2934203:0
  12. Asus K53S -X156V Thermal Paste Replacement, remove screws bottom plate: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus K53S -X156V Thermal Paste Replacement, remove screws bottom plate: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus K53S -X156V Thermal Paste Replacement, remove screws bottom plate: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    you unscrew the same screw at step 11 last picture. but you forget to unscrew the screw near wifi modul
  13. Asus K53S -X156V Thermal Paste Replacement, removing case: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus K53S -X156V Thermal Paste Replacement, removing case: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus K53S -X156V Thermal Paste Replacement, removing case: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • slide an isesamo opening tool between the two plates. you will here clicks
  14. Asus K53S -X156V Thermal Paste Replacement, reveal MAIN PCB: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus K53S -X156V Thermal Paste Replacement, reveal MAIN PCB: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus K53S -X156V Thermal Paste Replacement, reveal MAIN PCB: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • remove upper plate , revealing the main PCB.
  15. Asus K53S -X156V Thermal Paste Replacement, removing cable to usb module: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus K53S -X156V Thermal Paste Replacement, removing cable to usb module: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus K53S -X156V Thermal Paste Replacement, removing cable to usb module: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • remove the flat cable of the USB module , use a spudger to lift up the lid of the connector.
    • gently slide out the flat cable
    • when removing the cable, be carefull they used a lot of adhessive to paste the cable to the plastic case.
  16. Asus K53S -X156V Thermal Paste Replacement, removing LCD cable: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus K53S -X156V Thermal Paste Replacement, removing LCD cable: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus K53S -X156V Thermal Paste Replacement, removing LCD cable: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • use the tip of a spudger or a tiny flathead screwdriver to push out the LCD cable from connector.
    • be very very very carefull , if you tear tis cable or damage it , you will have to buy a new one.
    • first lift the cable metal connector upwards ( push it out) , very gently, then the other side untill you can remove the cable.
  17. Asus K53S -X156V Thermal Paste Replacement, remove audio cable: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus K53S -X156V Thermal Paste Replacement, remove audio cable: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • use IC extractor pliers to remove the cable away from is socket.
  18. Asus K53S -X156V Thermal Paste Replacement, remove screws main board: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus K53S -X156V Thermal Paste Replacement, remove screws main board: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus K53S -X156V Thermal Paste Replacement, remove screws main board: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • remove the 4 screws holding the main pcb ..
  19. Asus K53S -X156V Thermal Paste Replacement, removing last screw.: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • remove screw holding the fan tot the laptop.
  20. Asus K53S -X156V Thermal Paste Replacement, removing main board: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus K53S -X156V Thermal Paste Replacement, removing main board: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus K53S -X156V Thermal Paste Replacement, removing main board: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • lift the main board or motherboard up on the right side and slide it out.
  21. Asus K53S -X156V Thermal Paste Replacement, FAN: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus K53S -X156V Thermal Paste Replacement, FAN: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • release the fan from the main board by removing the connector with an IC extractor pliers.
  22. Asus K53S -X156V Thermal Paste Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus K53S -X156V Thermal Paste Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus K53S -X156V Thermal Paste Replacement: crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • loosen up the screws from the cooling pads on the CPU and GPU.
    • You will have to tear the warranty sticker. it is a sticker in 3 parts.
  23. Asus K53S -X156V Thermal Paste Replacement, removing fan and cooling pads: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus K53S -X156V Thermal Paste Replacement, removing fan and cooling pads: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus K53S -X156V Thermal Paste Replacement, removing fan and cooling pads: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • remove the fan and cooling pads.
    • you will see the old thermal paste.
  24. Asus K53S -X156V Thermal Paste Replacement, removing thermal paste from pads.: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus K53S -X156V Thermal Paste Replacement, removing thermal paste from pads.: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • clean the cooling pads with an very sharp knife. or spudger..
    • wear gloves, cause the thermal paste is very toxic.
    • also this is a good time to blow out the fan with compressed air.
  25. Asus K53S -X156V Thermal Paste Replacement, removing CPU and cleaning: crwdns2935265:025crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus K53S -X156V Thermal Paste Replacement, removing CPU and cleaning: crwdns2935265:025crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus K53S -X156V Thermal Paste Replacement, removing CPU and cleaning: crwdns2935265:025crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • remove the old thermal paste from the processors , be very carefull. and use some artic silver liquid to clean them. and easely remove the thermal paste.
    • you can remove the CPU by using a flathead screwdriver , the socket will move and you can pull the CPU out , maybe a good time to upgrade the CPU.
  26. Asus K53S -X156V Thermal Paste Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • unfortunately i don't have a picture when i added some new thermal paste. But if you do: one drop on each processor is enough.
    • Check out the thermal paste guide for more information on how to apply thermal paste.
crwdns2935229:09crwdne2935229:0
Kevin D
crwdns2935283:005/02/14crwdne2935283:0
7.418 crwdns2915208:0crwdne2915208:0
crwdns2935297:021crwdne2935297:0
crwdns2947412:05crwdne2947412:0
You dont have to disassembly whole computer, just remove back cover, 4 screws from cpu, 2 screws from gpu and 2 screws from fan..
Aleksi Kinnunen - crwdns2934203:0crwdne2934203:0
Hi Aleksi,
Yes we know, but we took the hole laptop apart to show how to replace, renew other parts as well.
Kevin D - crwdns2934203:0crwdne2934203:0
Ciao, io ho fatto tutto perfettamente in modo identico alla spiegazione (anche perché non è complicato). può essere la cpu?
Irene Montanari - crwdns2934203:0crwdne2934203:0
Which themal paste good . Please give amazon purchase link
Vinayak Patil - crwdns2934203:0crwdne2934203:0
Thank you. Pretty useful guide not to break connectors. went from 97ºC to 45ºC. I'm pretty happy.
The fan was blocked with dust and the thermal paste was like cement.
Marco Fidalgo - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 5,715
