Is your ASUS Chromebook Flip screen cracked, flickering, or completely unresponsive? Whether it’s physical damage or display issues that are slowing you down, this guide will walk you through the process of replacing the screen on your ASUS Chromebook Flip CX1400FKA-AS88F.
Before you begin this repair, make sure to power off your Chromebook and disconnect it from the charging adapter.
Using a Phillips #0 screwdriver, remove the eleven screws securing the bottom cover of the device.
Use an iFixit opening tool or nylon spudger to gently separate the bottom cover from the Chromebook.
Insert the tip of the opening tool into the seam between the top and bottom covers, then slide it along the perimeter to release the internal clips securing the case.
Once all clips are released, carefully lift and remove the bottom cover from the device.
Carefully disconnect ribbon cables attached to the motherboard.
Also carefully disconnect the fan cables that are connected to the motherboard.
Using a Phillips #0 screwdriver, remove the three 6.4 mm screws securing the metal brackets to the motherboard assembly.
Once the screws are removed, lift and remove the brackets from the device. Keep them in a safe place for reinstallation.
Disconnect the speaker wire connector from the motherboard by gently pulling it straight out of its socket using tweezers or your fingers.
Remove all tabs connecting the motherboard to other devices.
Unscrew all mounting screws securing the motherboard.
Carefully remove the motherboard from the base.
Remove the piece underneath the motherboard.
Unscrew the screws that attach the screen to the base.
Adjust the screen to easily lift from the case.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
