If the bottom case of your ASUS Chromebook Flip CX1400FKA-AS88F is cracked, scuffed, or you need to access internal components, use this guide to learn how to remove the back (bottom) casing.
Before you begin this repair, power off your device, and unplug the charging adapter and any peripherals.
Remove the ten screws from the bottom of the device.
Caution: be gentle with removing the screws. If you go too fast, you could strip and damage the screws on the bottom of the device.
Reminder: please put your screws somewhere visible and easy to see.
Use an iFixit opening tool or nylon spudger to separate the case from the device.
Place the tip of the opening tool in the seam between the front and back case and slide it around the perimeter of the device to release the clips holding it together.
Remove the back casing from your Chromebook.
Reminder: please use something plastic or silicone-based to pry the case off of the laptop. Using metal could damage the insides of something as delicate as your laptop.
Good job, everyone!!!
