Asus Chromebook Flip CX1400FKA-AS88F Battery Replacement
  1. Asus Chromebook Flip CX1400FKA-AS88F Battery Replacement, Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus Chromebook Flip CX1400FKA-AS88F Battery Replacement, Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus Chromebook Flip CX1400FKA-AS88F Battery Replacement, Case: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the ten screws from the bottom of the device.
    • Caution: be gentle with removing the screws. If you go too fast, you could strip and damage the screws on the bottom of the device.
    • Reminder: please put your screws somewhere visible and easy to see.
  2. Asus Chromebook Flip CX1400FKA-AS88F Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus Chromebook Flip CX1400FKA-AS88F Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus Chromebook Flip CX1400FKA-AS88F Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use an iFixit opening tool or nylon spudger to separate the case from the device.
    • Place the tip of the opening tool in the seam between the front and back case and slide it around the perimeter of the device to release the clips holding it together.
    • Use opening picks in the space to prevent the clips from reattaching.
    • Remove the back casing from your Chromebook.
    • Reminder: please use something plastic or silicone-based to pry the case off of the laptop. Using metal could damage the insides of something as delicate as your laptop.
  3. Asus Chromebook Flip CX1400FKA-AS88F Battery Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  4. Asus Chromebook Flip CX1400FKA-AS88F Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Chromebook Flip CX1400FKA-AS88F Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a screwdriver to remove the three 6.4 mm screws to loosen the brackets that hold the battery in place.
    • Remove the brackets.
    • Remove the 6.4 mm battery screw that was under the bracket.
  5. Asus Chromebook Flip CX1400FKA-AS88F Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Chromebook Flip CX1400FKA-AS88F Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently remove the battery from the laptop.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
KB BLACKMON @ UNT
crwdns2935283:001/31/25crwdne2935283:0
147 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 1-1, Kilpatrick Spring 2025 crwdns2935289:0University of North Texas, Team 1-1, Kilpatrick Spring 2025crwdne2935289:0
UNT-KILPATRICK-S25S1G1
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 80
