Asus Chromebook Flip C436F Battery Replacement
  1. Asus Chromebook Flip C436F Battery Replacement, Asus C436F Chromebook Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip your Chromebook over so the bottom case is facing up.
    • Use a Torx T5 screwdriver to remove ten 3 mm screws from the bottom of your device.
    • There are two screws under the rubber strip.
  2. Asus Chromebook Flip C436F Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the end of an opening tool into the seam between the bottom and top case to release the clips holding them together.
    • Remove the back panel of your Chromebook.
  3. Asus Chromebook Flip C436F Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the four M2 x 3 mm screws holding the battery to the chassis.
  4. Asus Chromebook Flip C436F Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Chromebook Flip C436F Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the white lock that connects the battery to the motherboard backward. Then, lift the connector out of the socket on the motherboard.
  5. Asus Chromebook Flip C436F Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery from your Chromebook.
To reassemble your device, follow these instructions in reverse order. For optimal performance, calibrate your newly installed battery after completing this guide.
RusselSprout
crwdns2935283:005/05/25crwdne2935283:0
121 crwdns2915208:0crwdne2915208:0
CSU Los Angeles, Team 5-90, Harris Spring 2025 crwdns2935289:0CSU Los Angeles, Team 5-90, Harris Spring 2025crwdne2935289:0
CSULA-HARRIS-S25S5G90
crwdns2936753:030crwdne2936753:0 47
crwdns2942667:0crwdne2942667:0 59
