Asus Chromebook Flip C302CA Touchpad Replacement
  1. Asus Chromebook Flip C302CA Touchpad Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the laptop over so the bottom is facing you.
  2. Asus Chromebook Flip C302CA Touchpad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus Chromebook Flip C302CA Touchpad Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus Chromebook Flip C302CA Touchpad Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove two rubber caps on the top.
    • Remove the two 1 mm screws using the Phillips #00 screwdriver.
  3. Asus Chromebook Flip C302CA Touchpad Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus Chromebook Flip C302CA Touchpad Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus Chromebook Flip C302CA Touchpad Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the ten 2 mm screws from the back panel using a T5 Torx screwdriver.
    • Carefully remove the back panel using an opening pick.
  4. Asus Chromebook Flip C302CA Touchpad Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Chromebook Flip C302CA Touchpad Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the back panel from the laptop.
  5. Asus Chromebook Flip C302CA Touchpad Replacement, Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus Chromebook Flip C302CA Touchpad Replacement, Battery: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus Chromebook Flip C302CA Touchpad Replacement, Battery: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the sticker holding the cable using a pair of tweezers.
    • Detach the cable from the motherboard by lifting it up with a spudger.
    • Always use a plastic or nylon ESD-safe tool. Metal spudger and other sharp tools can puncture a battery, potentially causing a fire.
  6. Asus Chromebook Flip C302CA Touchpad Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Chromebook Flip C302CA Touchpad Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 2 mm screws holding the battery using a Phillips #00 screwdriver.
  7. Asus Chromebook Flip C302CA Touchpad Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift up the battery from the front side to remove it from the laptop.
  8. Asus Chromebook Flip C302CA Touchpad Replacement, Speakers: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus Chromebook Flip C302CA Touchpad Replacement, Speakers: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus Chromebook Flip C302CA Touchpad Replacement, Speakers: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 2 mm screws from the speakers using a Phillips #00 screwdriver.
  9. Asus Chromebook Flip C302CA Touchpad Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus Chromebook Flip C302CA Touchpad Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus Chromebook Flip C302CA Touchpad Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Detach the cable that is connected to the motherboard using a pair of blunt tweezers.
  10. Asus Chromebook Flip C302CA Touchpad Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Chromebook Flip C302CA Touchpad Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove both speakers from the laptop and set them aside.
  11. Asus Chromebook Flip C302CA Touchpad Replacement, Touchpad: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the tab connected to the motherboard using tweezers.
  12. Asus Chromebook Flip C302CA Touchpad Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus Chromebook Flip C302CA Touchpad Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus Chromebook Flip C302CA Touchpad Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip up the ribbon cable tab using a pair of tweezers.
    • Disconnect the cable by holding the blue tab with your fingers and pulling out towards you.
  13. Asus Chromebook Flip C302CA Touchpad Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus Chromebook Flip C302CA Touchpad Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus Chromebook Flip C302CA Touchpad Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove three 3 mm screws from the trackpad using a Phillips #00 screwdriver.
  14. Asus Chromebook Flip C302CA Touchpad Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Chromebook Flip C302CA Touchpad Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Detach the ribbon cable and silver adhesive attached to the computer by pulling it up towards you.
  15. Asus Chromebook Flip C302CA Touchpad Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus Chromebook Flip C302CA Touchpad Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus Chromebook Flip C302CA Touchpad Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry up all around the edges where the screws were to loosen the trackpad.
  16. Asus Chromebook Flip C302CA Touchpad Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Chromebook Flip C302CA Touchpad Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up the trackpad to remove it from the laptop.
Zahid Enriquez
crwdns2935283:002/08/22crwdne2935283:0
543 crwdns2915208:0crwdne2915208:0
Gateway, Team 1-2, Saknee Spring 2022 crwdns2935289:0Gateway, Team 1-2, Saknee Spring 2022crwdne2935289:0
GCC-SAKNEE-S22S1G2
crwdns2942667:0crwdne2942667:0 466
