Asus Chromebook Flip C302CA Mother & Daughterboard Replacement
  1. Asus Chromebook Flip C302CA Mother & Daughterboard Replacement, Mother & Daughterboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the T5 Torx Screwdriver, remove the ten 5 mm screws from the back panel.
    • Remove the rubber caps at the top of the panel. Then, using the Phillips #00 Screwdriver, remove the two 1 mm screws underneath.
    • Lift up the back panel.
  2. Asus Chromebook Flip C302CA Mother & Daughterboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using Tweezers, carefully remove the black wire connected to the audio card.
    • Repeat this process for the white wire.
  3. Asus Chromebook Flip C302CA Mother & Daughterboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 2.5 mm screws securing the battery
    • Remove the connector from the motherboard by pulling straight up on it.
    • Carefully lift the battery out of the laptop.
  4. Asus Chromebook Flip C302CA Mother & Daughterboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the highlighted strips connected to the top of the display.
  5. Asus Chromebook Flip C302CA Mother & Daughterboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the white tab highlighted in the image. Then, disconnect the blue connector by pulling away from the motherboard.
  6. Asus Chromebook Flip C302CA Mother & Daughterboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the black tab highlighted in the photo. Then, repeat the same process mentioned above.
  7. Asus Chromebook Flip C302CA Mother & Daughterboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once again, lift the white tab highlighted in the image. Then, pull the brown connector away to disconnect it from the motherboard.
  8. Asus Chromebook Flip C302CA Mother & Daughterboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the Phillips #00 Screwdriver, remove the two highlighted 1 mm screws attaching the heatsink (highlighted in orange) to the motherboard.
    • Then, remove the heatsink from the motherboard.
  9. Asus Chromebook Flip C302CA Mother & Daughterboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the Philips-Head #00 Screwdriver, remove the eleven 2.5 mm screws that secure the motherboard.
    • With the same tool, remove the four 1.3 mm screws at the bottom of the mother board/daughterboard.
    • Replace the motherboard/daughterboard.
NICKO SANTOS SALEM
crwdns2935283:010/03/22crwdne2935283:0
529 crwdns2915208:0crwdne2915208:0
The Citadel Military College of South Carolina, Team 1-12, Eggleston Fall 2022 crwdns2935289:0The Citadel Military College of South Carolina, Team 1-12, Eggleston Fall 2022crwdne2935289:0
CMCSC-EGGLESTON-F22S1G12
crwdns2942667:0crwdne2942667:0 423
