Asus Chromebook C202 Battery Replacement
  1. Asus Chromebook C202 Battery Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus Chromebook C202 Battery Replacement, Back Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus Chromebook C202 Battery Replacement, Back Panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • What you need: 10 8mm screws, Tweezers, and a Phillips #1 Screwdriver
    • Remove Phillips #1 screws from the bottom of the Chromebook using a Phillips #1 screwdriver.
    • Use tweezers to get two of the screws are hidden by rubber caps along the rubber rest of the device out.
  2. Asus Chromebook C202 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    iFixit Opening Tool
    $1.99
    • What you need: plastic opening tool, Chromebook
    • Place the plastic opening tool facing upward using the upper scoop, into the edges between the front and back of the Chromebook.
    • Open the top portion of the Chromebook
    • To unhinge the top portion of the Chromebook, push down on the plastic opening tool.
    • In order to avoid damaging ribbon cables, gently lift the top portion of the Chromebook from the bottom portion.
  3. Asus Chromebook C202 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently disconnect the ribbon cable connecting the trackpad and the keyboard to the motherboard.
  4. Asus Chromebook C202 Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus Chromebook C202 Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus Chromebook C202 Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger or a clean fingernail to flip up the locking flap on each end of the cable—this is the unlocked position.
    • Gently remove the ribbon cable connecting the I/O board to the motherboard.
  5. Asus Chromebook C202 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus Chromebook C202 Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus Chromebook C202 Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove two 4 mm Phillips #1 screws from the metal grate connected to the battery.
    • Remove metal grate from battery.
    • Remove six 4 mm Phillips #1 screws from the battery.
  6. Asus Chromebook C202 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Chromebook C202 Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger to push on alternating sides of the connector to "walk" it out of its socket and disconnect the battery from the motherboard.
    • It may take a lot of alternating before the connector comes out. Be patient.
    • If that doesn't work, grip all the cables at once as close to the connector as possible and pull the connector slowly and steadily out of its socket.
    • Lift the battery from the bottom edge to to remove it from the Chromebook.
To reassemble your device, follow these instructions in reverse order. For optimal performance, calibrate your newly installed battery after completing this guide.
Christopher Segale
crwdns2935283:009/28/16crwdne2935283:0
922 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 3-1, Passmore Fall 2016 crwdns2935289:0USF Tampa, Team 3-1, Passmore Fall 2016crwdne2935289:0
USFT-PASSMORE-F16S3G1
Worked great. Was able to order a replacement battery for my daughter’s two year old Chromebook. $39.99 and relatively easy to swap out.
Ben McCormack - crwdns2934203:0crwdne2934203:0
You did such a great job writing this documentation. I would not consider myself to be good at taking apart things and putting them back together again but your amazing pictures showing each step of the process gave me the confidence to try it myself! It was perfect and exactly what I needed to get this switched out!
peasem7 - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 5,580
