Astro Mixamp USB Port Replacement
crwdns2942287:0crwdne2942287:0Use when the USB port needs to be removed. (Soldering Required)
crwdns2944105:0crwdne2944105:0
Grip the dial tightly and pull straight off the device.
Repeat for the second dial
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using tweezers, remove the spacer nuts and washers from each dial post.
Insert a plastic opening tool into the seam between the rubber foot and plastic casing.
Pull the rubber foot free of the plastic casing.
Use a screwdriver to remove the screw from the rear casing.
Gently lift the rear casing from the device.
The Astro Mixamp Pro is largely the same process as this, except there are some plastic tabs on the rear casing holding it onto the front plate. Carefully work along the seams on the long sides and the corners with something flat and stiff, gently levering the rear housing out and away from the front plate to disengage the plastic tabs. With enough patience and care, they'll pop out of their spots and the casing will be free.
Remove the four screws that hold the motherboard in place.
Gently pull the motherboard from the front cover.
Press the tip of a hot soldering iron to the USB connection to melt the solder.
Use a nylon spudger to lift the USB from the solder.
Repeat for each of the four USB connections.
What port is used as a replacement?
Did you ever identify an appropriate replacement port?
Lepec -
something was broken out of the port of the USB connection
Will this method work with the 2015 tr mixamp?
