Artemide Tolomeo switch replacement
  1. Artemide Tolomeo switch replacement, Switch: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Never forget to disconnect the power plug before starting repairs.
    • Unscrew the Phillips screw on the clamp. You may have to hold the nut on the opposite side.
  2. Artemide Tolomeo switch replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully press the clamp apart, using a suitable tool if necessary.
    • Lift the flanged edge of the lampshade out of the clamp.
    • Remove the lampshade.
    Bei mir war die Spannzwinge so alt, dass sie schon zerbrach, als ich sie den ersten Millimeter auseinandergedrückt habe.
    Habe zähneknirschend das ganze Gabelgelenk mit Spannzwinge bestellt. Bei mittelicht DE waren das 28,42 + 4,20 Versand.
    Johannes Schmidt - crwdns2934203:0crwdne2934203:0
    Immerhin gut zu wissen, dass man sie nachkaufen kann.
    VauWeh -
  3. Artemide Tolomeo switch replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Artemide Tolomeo switch replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The cover of the socket also has a flanged edge. Lift the cover together with the socket out of the clamp.
  4. Artemide Tolomeo switch replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Artemide Tolomeo switch replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Artemide Tolomeo switch replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The socket is fixed at the top with a wide ring. This ring is secured against unscrewing by a small brass catch.
    • Press the brass catch with a small flat-blade screwdriver about 1 mm toward the center of the socket. Do not bend the brass catch too much.
    • Depending on the socket, the notch may look different. You may have to push it down.
    • Then unscrew the wide ring on the lamp socket.
    Can’t seem to unscrew or loosen wide ring from socket. Are you pressing and turning at the same time?
    LCS - crwdns2934203:0crwdne2934203:0
    Same issue. Can’t unscrew wide ring from socket.
    asojaff - crwdns2934203:0crwdne2934203:0
    It is a kind of pawl that has to be pushed to the side or downwards. The ring can be turned at the same time.
    VauWeh -
    oberer und untere Ring sind tw recht stramm zusammen, habe mit 2 Wasserpumpenzangen vorsichtig bei gelöst, hat alles sonst super nach der Anleitung geklappt
    Karsten D - crwdns2934203:0crwdne2934203:0
    Der Ersatz des Wippschalters und vor allem der Zusammenbau der Artemide war mit der Anleitung kein Problem, vielen Dank dafür
    Ralf - crwdns2934203:0crwdne2934203:0
    I’ve changed the switches on several of Tolomeo lamps with no problems.
    Maybe 4 or 5 switches over time.
    They’ve clearly changed the design, because the one the I’m trying to fix now has this pivoting thing.
    However, it’s impossible to unscrew the socket.
    I love my Tolomeo lamps, but these switches have always been absolute garbage.
    Somehow, they managed to make them even worse.
    Now it’ll cost me over $100 to ship it to Artemide for repair AND no lamp for at least a month.
    Great.
    jeffharris - crwdns2934203:0crwdne2934203:0
  5. Artemide Tolomeo switch replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The cable is secured by a strain relief on the outside. Unscrew the plastic Allen screw until the cable is loose.
    See comments at the end. Some lamps are secured differently without the plastic screw.
    John E. - crwdns2934203:0crwdne2934203:0
  6. Artemide Tolomeo switch replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Artemide Tolomeo switch replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Artemide Tolomeo switch replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the unit out of the switch and lamp socket.
  7. Artemide Tolomeo switch replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Artemide Tolomeo switch replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Artemide Tolomeo switch replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Loosen the two small screws that connect the inner part of the socket and the switch to the two power supply lines.
    • Replace the unit.
  8. Artemide Tolomeo switch replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Artemide Tolomeo switch replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Here is a picture of the switch. You can buy the complete set quite expensive from Artemide, because the socket has been machined by hand. This has the advantage that you can also renew the socket.
    • You may also find the switch on its own, which is cheaper. It is a snap-in rocker switch with screw connection. The cutout size is 20 x 14 mm, 15 mm installation depth from the frame. The frame is 3 mm high with the dimensions 26x16 mm. This one could fit.
    ich konnte den Schalter reparieren, indem ich die Wippe vorsichtig herausgehebelt habe. die inneren Kontakte waren verschmutzt und das u-förmige Schaltelement war zu sehr zusammengedrückt. nach dem reinigen (elektronik-reiniger) schaltet es wieder perfekt
    Clemens Schwarz - crwdns2934203:0crwdne2934203:0
    In my case I didnt have to replace. I opened the plactic part of the switch, there is a small thin metal plate. Take it out, clean the contact and bend it a little bit, put it back. Now it works again.
    Jakub Loučka (JL) - crwdns2934203:0crwdne2934203:0
    Super Anleitung...und der empfohlene Kippschalter passt und funktioniert. Kosten: 4.95 plus Porto. Original Schalter momentan 30€. Herzlichen Dank!
    Walter Binanzer - crwdns2934203:0crwdne2934203:0
Work through the steps in reverse order to reassemble your device.
crwdns2935229:010crwdne2935229:0
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934883:0oldturkey03crwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
VauWeh
crwdns2935283:010/19/15crwdne2935283:0
256 131 crwdns2915208:0crwdne2915208:0
crwdns2935297:0286crwdne2935297:0
Repair is War on Entropy crwdns2935289:0Repair is War on Entropycrwdne2935289:0
Community
crwdns2931471:029crwdne2931471:0
crwdns2935297:01 776crwdne2935297:0
crwdns2947412:014crwdne2947412:0
Thanks for the article. When I get to step 5, I don't see an Allen screw. See the linked images. Do you know how I would remove the cable from the socket?
Socket photo 1
Socket photo 2
Thanks!
OK, I figured it out, needed to press down on the metal clip in photo 3.
John E. -
Fixed with a white switch.
New white switch.
John E. -
Well done, like it.
VauWeh -
Thanks for hte comment!
John E. -
thank you so much! it worked perfectly for DIY repairing my Tolomeo
c-j - crwdns2934203:0crwdne2934203:0
If you are unable to locate a replacement switch, you can find a listing on the sfbay craigslist website by searching on: tolomeo switch
And now, how to get the hood back and close it??
Knisper - crwdns2934203:0crwdne2934203:0
Thank you so much for taking the time to compile this @vauweh ! Super greatful. It took me approx. 1 hour including getting all tools together, set it up, repair it and clean the desk.
The recommended Amazon switch worked well (<5 EUR). My Tolomeo was bought around 2020 or so. It took me a while to figure out step 4.
In my case I needed to press the lever on the outer diameter down so that the big ring can rotate over the lever. More light helped to see the mechanism (bad luck if your lamp is broken!).
My original issue was that my Tolomeo randomly turned off but not on again. It sometimes took a couple of days until it turned on again. Then after a couple of minutes it turned off again. Right now it seems to work with the new switch. So thank you for explaining how the repair works!
Max Foxy - crwdns2934203:0crwdne2934203:0
@maxfoxy Thank you, glad I could help.
VauWeh -
Didn't find the switch on "SF Craigslist".
Microsoft AI returned the following. I've ordered two.
Only $1.05 each + $5.16 shipping!
https://grandbrass.com/snap-in-rocker-sw...
SKU: SW144B
Function: On/Off
Type: Switch - Fixture - Toggle
Color/ Finish: Black
Length: 1.000 (1in)
Height: 0.812 (13/16in)
Width: 0.625 (5/8in)
Voltage (Max): 125V, 250V
Certification: cRUus, ENEC
Joe S - crwdns2934203:0crwdne2934203:0
Ich habe das umgekehrte Problem: der Lampenschirm hängt auf einmal lose dran, und ich weiß nicht, wie ich ihn da wieder rein kriegen soll.
Bea - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 18
crwdns2936753:07crwdne2936753:0 101
crwdns2936753:030crwdne2936753:0 361
crwdns2942667:0crwdne2942667:0 12,042
