Arlo Ultra 2 Camera Lens Replacement
  1. Arlo Ultra 2 Camera Lens Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Arlo Ultra 2 Camera Lens Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press the button on the bottom of the camera to release the case.
    • Pull the white case off of camera.
  2. Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the white cube shaped battery from the back to remove it from camera.
  3. Arlo Ultra 2 Camera Lens Replacement, Speaker: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Arlo Ultra 2 Camera Lens Replacement, Speaker: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the four 20.0 mm screws from the battery cavity. They are found in each corner.
  4. Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the spudger, loosen and remove the camera faceplate.
  5. Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the spudger, loosen and remove the back casing to expose the camera hardware.
  6. Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Very gently, pry the circuit boards apart from the white connector, removing the upper circuit board.
  7. Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove two 5.0 mm screws from the metal bracket.
    • Use a spudger to separate the long metal bracket.
    • There is an arrow etched into the bracket. It points towards the top of the camera. This is important when reassembling the camera.
  8. Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the tip of a spudger or your fingernail to flip up the small locking flap on each ZIF connector. Then, you can safely pull the cables out.
    • Be sure to pry up on the hinged flap, not the connector socket.
  9. Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to carefully push on each side of the speaker cable connector until it's out of its socket.
  10. Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the small green circuit board.
  11. Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Feed the speaker cable through the opening to remove the speaker.
  12. Arlo Ultra 2 Camera Lens Replacement, Camera Lens: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Arlo Ultra 2 Camera Lens Replacement, Camera Lens: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Arlo Ultra 2 Camera Lens Replacement, Camera Lens: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the two 5.0 mm screws from both sides of the metal plate.
    • Pry the metal plate away from circuit board underneath.
    • There is a small amount of blue putty in between the metal plate and the circuit board.
  13. Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to remove the entire green circuit board with lens attached.
  14. Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove three black 5.0 mm screws from back of the circuit board.
    • Separate the lens from the circuit board.
    • There is a small cord connecting the lens and circuit board.
  15. Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to carefully push on each side of the white cable connector to remove it from the socket and separate the camera lens from the board.
  16. Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the two 4.0 mm screws from the side of the lens body.
  17. Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Arlo Ultra 2 Camera Lens Replacement: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the blunt tweezers to remove the focus motor control insert from the main lens body.
Xavier Feaster-Rivera
crwdns2935283:001/23/23crwdne2935283:0
449 crwdns2915208:0crwdne2915208:0
Linn Benton Community College, Team 1-4, Karnes Winter 2023 crwdns2935289:0Linn Benton Community College, Team 1-4, Karnes Winter 2023crwdne2935289:0
LBCC-KARNES-W23S1G4
crwdns2947412:07crwdne2947412:0
Any ideas on where to get the lens ordered?
Jerald Buechler - crwdns2934203:0crwdne2934203:0
I called Arlo and they said they don’t sell a replacement. I couldn’t find it anywhere online either. Does anybody know where to get a replacement?
Barry Bonds - crwdns2934203:0crwdne2934203:0
My was badly scratched and I would like to replace the lens but I can't find any arlo lenses for sale. Plenty other ones but not arlo one.
Karol jar - crwdns2934203:0crwdne2934203:0
Has anyon found where to buy a replacement lens? Mine is cracked and unusable without a new lens.
Digit Holder - crwdns2934203:0crwdne2934203:0
My Arlo ultra lens fell out and smashed whilst swapping out the battery, the inertia from the tap dislodged the poorly fix lens, now I cant find a replacement
Paul Heslin - crwdns2934203:0crwdne2934203:0
Unfortunately, not much help without a source for replacement part.
troykirchenbauer - crwdns2934203:0crwdne2934203:0
Die Demontage-Anleitung ist leider nicht zu gebrauchen wenn es keine Ersatzteilquelle gibt. Schade.
Marco Thamm - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 71
crwdns2942667:0crwdne2942667:0 1,467
