Arlo Pro 2 Camera Micro-USB Port Replacement
  1. Arlo Pro 2 Camera Micro-USB Port Replacement, Camera Motherboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Arlo Pro 2 Camera Micro-USB Port Replacement, Camera Motherboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Arlo Pro 2 Camera Micro-USB Port Replacement, Camera Motherboard: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press the release button on the camera and gently pull apart the casing to open the device.
    • Remove the battery from inside the case.
  2. Arlo Pro 2 Camera Micro-USB Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Arlo Pro 2 Camera Micro-USB Port Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Arlo Pro 2 Camera Micro-USB Port Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a T5 Torx screwdriver to remove the four 7 mm screws securing the camera case.
    • Carefully pull the outside of the case apart from the internal case to remove the camera components from the outside casing.
  3. Arlo Pro 2 Camera Micro-USB Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Arlo Pro 2 Camera Micro-USB Port Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Arlo Pro 2 Camera Micro-USB Port Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove four 4 mm screws connecting the daughterboards to the motherboard.
    • Seperate the daughterboards from the motherboard and camera casing.
  4. Arlo Pro 2 Camera Micro-USB Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Arlo Pro 2 Camera Micro-USB Port Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Arlo Pro 2 Camera Micro-USB Port Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Flathead 4 mm screwdriver to remove the four 7 mm screw posts connecting the motherboard to the case.
    • Carefully pull the motherboard apart from the camera casing.
  5. Arlo Pro 2 Camera Micro-USB Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Arlo Pro 2 Camera Micro-USB Port Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the white cord from the port on the motherboard, by gently pulling away from the port to fully isolate the motherboard from the case.
  6. Arlo Pro 2 Camera Micro-USB Port Replacement, Camera Micro-USB Port: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Arlo Pro 2 Camera Micro-USB Port Replacement, Camera Micro-USB Port: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Thread the wires of the Micro-USB port through the casing.
    • Guide the wiring through the opening so that the wiring is solely in the battery cavity and not going through any part of the case.
  7. Arlo Pro 2 Camera Micro-USB Port Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Arlo Pro 2 Camera Micro-USB Port Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Arlo Pro 2 Camera Micro-USB Port Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove two 3 mm screws connecting the Micro-USB port to the camera casing.
    • Gently remove the Micro-USB port by pulling it away from the case.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Ben I.
crwdns2935283:003/26/25crwdne2935283:0
493 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 2-2, Botvin Spring 2025 crwdns2935289:0UMass Dartmouth, Team 2-2, Botvin Spring 2025crwdne2935289:0
UMASSD-BOTVIN-S25S2G2
Great guide, I was able to remove the Micro USB Charge Port and Cable from the arlo PRO 2 (Model: VMC4030P) without having to remove the System Board. However finding a replacement part is the tricky part. I stumbled across this guide after removing the cable hoping an iFixIt guide might have a link to a part source.
tech2life - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 298
