crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Apple Watch Series 5crwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Apple Watch Series 5 Teardown, Apple Watch Series 5 Teardown: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Apple Watch Series 5 Teardown, Apple Watch Series 5 Teardown: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Apple Watch Series 5 Teardown, Apple Watch Series 5 Teardown: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • A quick comparison of the Series 5 with yesteryear's edition tells us ... very little actually. We'll need to put our spudgers to work mining for differences. To start with, here are the details we know:
    • LTPO OLED Retina display with Force Touch, optimized for always-on functionality
    • Custom-designed Apple 64-bit dual-core S5 SiP (System in Package)
    • Heart rate sensor and ECG
    • Comes in GPS-only or with optional LTE and brings a compass and ground elevation
    • Water resistance to a depth of 50 meters
  2. Apple Watch Series 5 Teardown: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Apple Watch Series 5 Teardown: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Apple Watch Series 5 Teardown: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The model number doesn't lie: A2157 tells us it really is a new Apple Watch.
    • Although the usual heat-and-slice action opens up the display, this model was clam-shelled shut a bit tighter than we expected.
    • The Force Touch gasket connector sits in its corner behind the display cables, where it moved with the last iteration.
  3. Apple Watch Series 5 Teardown: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Apple Watch Series 5 Teardown: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Apple Watch Series 5 Teardown: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnecting the power requires first extracting the glued-down battery, which we know how to do (although we reserve the right to make a grumpy face as we do it).
    • This year’s energy source is labeled A2181 and provides 1.129 Wh (296 mAh at 3.814 V).
    • That amounts to a very slight 1.44% improvement over last year's 1.113 Wh battery. It's clear that battery improvements didn't drive the switch to the 18-hour always-on display—that technology is being enabled by something else.
  4. Apple Watch Series 5 Teardown: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Apple Watch Series 5 Teardown: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Apple Watch Series 5 Teardown: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Teardown Update: We cut into the smaller 40 mm Apple Watch Series 5, and found a surprising new battery design with a 10% capacity boost. We can only speculate as to why the 44 mm watch didn't get this upgrade, but you can read all about our findings over here.
  5. Apple Watch Series 5 Teardown: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Watch Series 5 Teardown: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The new LTPO display on the Series 5 (left) doesn’t seem to physically look all that different from last year's Series 4 display (right)—which also used LTPO technology. But Apple has been busily tinkering under the hood.
    • We know there's at least a new display driver and power management IC in there somewhere to enable the always-on feature. Without a significantly bigger battery, this watch stays awake by sipping power more efficiently.
    • The LTE antenna connector occupies its usual spot, but a change in form factor prevents these displays from ever working interchangeably.
    • The resolution and dimensions are still the same: 368 × 448 pixels on the 44 mm version covering 977 sq mm.
  6. Apple Watch Series 5 Teardown: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Watch Series 5 Teardown: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After carefully tweezing the Taptic Engine away from an antenna connector, we can have a closer look for comparison.
    • Again, they look superficially very similar—but at the very least the connectors have been re-engineered, so we know the parts won't be compatible with last year's models.
  7. Apple Watch Series 5 Teardown: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Watch Series 5 Teardown: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With enough screws removed, the rest of the watch drops out the bottom, more or less as we remember from the Series 4:
    • We leave the digital crown, microphone, and side button clinging to the frame ...
    • ... whereas the heart rate sensor, ECG components, and charging coil escape with the bottom plate.
    • We'll focus the rest of our attention on what's between: the S5.
  8. Apple Watch Series 5 Teardown: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Apple Watch Series 5 Teardown: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Apple Watch Series 5 Teardown: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Out comes this ticker’s brain, the all-new—or maybe not?—S5 system-in-package.
    • Although it benefits from a new compass and double the onboard storage—32 GB, up from 16—most of the integrated circuits remain entombed under a solid layer of resin, out of our reach. Of the few chips above the surface, here's what we can make out:
    • Skyworks 229-15 465371 1918 MX, most likely front-end module
    • 16 CJ
    • YY NCJ 7NE (likely the acceleration + gyro sensor)
    • API 924 920
    • Looking at the attached display flex cables and laying them over those of the Series 4 for comparison, we can see that the plug in the middle gained 4 pins and the one on the bottom gained 2. Without knowing their function, this closes the door on interchangeability.
  9. Apple Watch Series 5 Teardown: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • That's as far as we go. Although this year's always-on display is a huge leap forward in functionality, it's masked by surprisingly subtle changes in the underlying physical components.
    • Same basic construction, similar-looking components, and same amazing engineering in a mildly-annoying-to-open package. Plus a wild new battery design that only benefits the smaller version of the watch, for now.
    • What does it all mean in terms of repairability?
  10. crwdns2935195:0crwdne2935195:0
    • Screen replacements are difficult but do-able—it's the first thing to come off, and detaches via ZIF connectors.
    • Battery replacements are pretty straightforward, once you're inside.
    • Still a lot of incredibly tiny tri-point screws are used throughout the watch.
    • Several component flex cables are mounted directly to the S5 package, requiring skilled microsoldering to replace.
    crwdns2935097:0crwdne2935097:0
    6
    crwdns2935197:06crwdne2935197:0
    crwdns2935199:0crwdne2935199:0
Tobias Isakeit
crwdns2935283:003/31/14crwdne2935283:0
125,687 crwdns2915208:0crwdne2915208:0
crwdns2935297:0189crwdne2935297:0
Tobias Isakeit - Repairability Engineer crwdns2935289:0Tobias Isakeit - Repairability Engineercrwdne2935289:0
Business
crwdns2935297:01,136crwdne2935297:0
crwdns2947412:013crwdne2947412:0
I’m not sure if the crown can be replaced after all. I tried to get it off on the Series 4 without success (the stem broke). Apple Watch Series 4 Teardown
Tobias Isakeit -
What can I do if the backside has scars?
Kocher Sven - crwdns2934203:0crwdne2934203:0
I’m pretty sure you can replace the whole back housing (glass + heart rate sensor assembly, which u can find on ali)
Richard Kraus -
Savez vous si le bouton fonctionne si un composant de l’écran est abîmé ?
en changeant l’écran sans vérifier avant si le bouton Digital Crown fonctionnait.
BESENG - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 16
crwdns2936753:07crwdne2936753:0 100
crwdns2936753:030crwdne2936753:0 459
crwdns2942667:0crwdne2942667:0 72,699
