Apple Magic Keyboard 2 A2450 Lightning Port Replacement
  1. Apple Magic Keyboard 2 A2450 Lightning Port Replacement, Lower Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Apple Magic Keyboard 2 A2450 Lightning Port Replacement, Lower Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Apple Magic Keyboard 2 A2450 Lightning Port Replacement, Lower Case: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply heat around the perimeter of the lower case to loosen the adhesive that secures the lower case to the chassis.
    • The plastic should be a bit too warm to touch comfortably, but not hot.
    • Insert an opening pick in the gap between the lower case and chassis.
    • After ensuring that the adhesive is warm, slide the pick around the perimeter to sever the adhesive.
    • As you sever the adhesive, insert additional opening picks at each corner to prevent the adhesive from readhering.
    • Remove the lower case.
  2. Apple Magic Keyboard 2 A2450 Lightning Port Replacement, Lightning Port: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Apple Magic Keyboard 2 A2450 Lightning Port Replacement, Lightning Port: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Apple Magic Keyboard 2 A2450 Lightning Port Replacement, Lightning Port: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a T3 Torx screwdriver head to remove all twelve 5 mm that secure the midframe.
    • Use tweezers to disconnect the battery motherboard connection.
    • Remove the midframe.
  3. Apple Magic Keyboard 2 A2450 Lightning Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Apple Magic Keyboard 2 A2450 Lightning Port Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Apple Magic Keyboard 2 A2450 Lightning Port Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a T3 Torx screwdriver to remove the two 5 mm screws that secure the lightning port.
    • Use tweezers to remove the Lighting port from the motherboard.
Alex
crwdns2935283:004/02/24crwdne2935283:0
217 crwdns2915208:0crwdne2915208:0
IUPUI, Team 3-2, Harley Spring 2024 crwdns2935289:0IUPUI, Team 3-2, Harley Spring 2024crwdne2935289:0
IUPUI-HARLEY-S24S3G2
I am glad I found this post. I broke the cable from the lighting port on the Apple Keyboard 2 A2450 (touch id, not numeric pad) and would like to find a new lightning port and cable. Can you point me to a place where I can buy this please. I think I need to lighting port and the cable because it seems that the cable cannot be removed from the lighting port.
Peter Saunders - crwdns2934203:0crwdne2934203:0
i also would need the lightning port for the Appel key board can we buy it from you side?
Bernhelm - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 212
