Apple AirPort Extreme Model A1354 Outer Case Replacement
  1. Apple AirPort Extreme Model A1354 Outer Case Replacement, Outer Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • First start by peeling off the outer rubbery covering on the bottom of the device.
    • CAUTION: This part is very fragile, so it is recommended that a blow dryer is used on the covering to heat it up. Simply blow dry the covering while slowly peeling it away, and the covering will not tear.
    By the time I needed to open my AirPort Extreme in mid-2019, the adhesive bond to the covering had weakened to the point that the covering readily peeled away cleanly without the application of heat. I just worked slowly and carefully.
    The covering had no residue of adhesive on it after removal, but there was a sheet of adhesive clinging to the plastic surface of the body of the unit. I had to poke holes in it to reach the screws, but that was no big deal and easily done.
    When finished, the rubbery covering adhered to the body of the unit again adequately without the use of additional adhesive or (as I had planned to use) double-sided tape.
    BTW I was not disassembling the unit to replace the battery, but rather to reset the device by bridging the contacts that a broken reset switch failed to connect. (The switch had become detached from the circuit board and was literally hanging by a thread when I opened the case and fell off altogether as I examined it.)
    Thanks for the clear disassembly instructions!
    gambaguru+fb - crwdns2934203:0crwdne2934203:0
    When I performed this, the rubber had deteriorated(?) and tore quite easily, particularly around the model number label.
    Steve I - crwdns2934203:0crwdne2934203:0
  2. Apple AirPort Extreme Model A1354 Outer Case Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After removing the rubber covering, unscrew the five 4.9mm Phillips screws in the holes of the plastic casing.
    Use a #0 Phillips driver for these screws. Knowing they are 4.9mm is not necessary unless one needs to be replaced.
  3. Apple AirPort Extreme Model A1354 Outer Case Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After unscrewing all five screws, remove the plastic casing. The back should now look like the picture shown.
  4. Apple AirPort Extreme Model A1354 Outer Case Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Apple AirPort Extreme Model A1354 Outer Case Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Apple AirPort Extreme Model A1354 Outer Case Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The inner metal casing is latched inside the outer white plastic shell, so insert a pry tool underneath the metal casing and pry it apart from the shell.
    • It should make a click when it comes apart.
  5. Apple AirPort Extreme Model A1354 Outer Case Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the outer casing.
    • The exposed logic board should look like this.
    Remove the 3 connectors from the logic board to the antennas before removing the logic board from the metal surround.
    Dan McGoldrick - crwdns2934203:0crwdne2934203:0
    My unit, still A1354, had FOUR antennas. The logic board was labeled 820-2622-A copyright 2009.
Brandon
crwdns2935283:004/02/12crwdne2935283:0
387 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 5-2, Forte Spring 2012 crwdns2935289:0Cal Poly, Team 5-2, Forte Spring 2012crwdne2935289:0
CPSU-FORTE-S12S5G2
This guide also applies to model A1408.
Jonas Nilsson - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 4,462
