Apple AirPort Extreme Model A1143 Wi-Fi Card Replacement
  1. Apple AirPort Extreme Model A1143 Wi-Fi Card Replacement, Back Pad: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The back pad is held in with glue so use caution when removing to prevent tearing. Low heat may be used to help remove the pad.
    • Slowly peel off the rubber pad on the bottom of the device. Start from one corner and peel with your fingers. Use heat if necessary until pad is completely removed.
    This is where you would use the opening tool. It’s the perfect tool to lift the rubber base around the metal lip and then pull with your fingers.
    Eddie de la Rosa - crwdns2934203:0crwdne2934203:0
  2. Apple AirPort Extreme Model A1143 Wi-Fi Card Replacement, Back Cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After removing the rubber pad, unscrew the five 5mm phillips #00 screws in the holes of the back cover.
  3. Apple AirPort Extreme Model A1143 Wi-Fi Card Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up the back case from the perforated edge to remove it.
  4. Apple AirPort Extreme Model A1143 Wi-Fi Card Replacement, Remove from Case: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove logic board and metal casing from outer case by prying from one side using a spudger.
    I have found it easier to lift from the side with the Ethernet ports. When putting back together watch that the three WI-FI antennas don’t get snagged against the case as your putting back.
    Take care to remove the small pieces of metallic tape between the case and the spring copper comb earthing strips in the case.
    If you do not, it is a real fiddle to put them back in place latter (the tape will pull them out of the case ground steps)
    Robert.
    PS: I believe the onboard power converter is bust: the board sings when power turned on. So to trash it goes.
    (external power supply is good), swapped with another to test).
    Sad…
    Robert McInnes - crwdns2934203:0crwdne2934203:0
  5. Apple AirPort Extreme Model A1143 Wi-Fi Card Replacement, Detach Logic Board From Case: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unhook the wires connecting the logic board to the metal casing by grabbing and pulling up on each connection with tweezers.
  6. Apple AirPort Extreme Model A1143 Wi-Fi Card Replacement, Pull Back Tabs: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully push back the three metal tabs with your fingers on the sides of metal case.
  7. Apple AirPort Extreme Model A1143 Wi-Fi Card Replacement, Remove Metal case: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pull the metal case away from the logic board.
  8. Apple AirPort Extreme Model A1143 Wi-Fi Card Replacement, Unhooking the WiFi Card: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the WiFi card on the logic board, then use the prying tool to bend back the plastic holding it in place.
    • Be careful when prying back the plastic piece, it can break if bent too far.
  9. Apple AirPort Extreme Model A1143 Wi-Fi Card Replacement, Removing the WiFi Card: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After holding back the plastic piece keeping the card in place, lift the card up and pull it away from the logic board.
Zak
crwdns2935283:009/23/14crwdne2935283:0
616 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 12-4, Blackwell Fall 2014 crwdns2935289:0USF Tampa, Team 12-4, Blackwell Fall 2014crwdne2935289:0
USFT-BLACKWELL-F14S12G4
What types of mini pci wifi cards are supported?
Dan S - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 3,320
