crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Anko Milk Frother SB-0802C1crwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Anko Milk Frother SB-0802C1 Teardown, Separate the bottom: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anko Milk Frother SB-0802C1 Teardown, Separate the bottom: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The three screws to open this product are hidden beneath the rubber feet.
    • Use a spudger or small screw driver to pry out the three rubber feet.
    • Remove the three screws.
  2. Anko Milk Frother SB-0802C1 Teardown, Undo the power connections: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anko Milk Frother SB-0802C1 Teardown, Undo the power connections: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anko Milk Frother SB-0802C1 Teardown, Undo the power connections: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There are 5 spade connectors providing power from the bottom assembly to the PCB, and from the PCB to the heating element.
    • These connectors have a release latch hidden under their heat shrink. You may see a little bulge. You need to depress this latch before you can pull the spade connector off.
  3. Anko Milk Frother SB-0802C1 Teardown, Slide the milk container out of the shell: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anko Milk Frother SB-0802C1 Teardown, Slide the milk container out of the shell: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • NOTE - When these last connections are removed, there is nothing stopping the heavier milk container assembly to slide out of the outer shell.
    • So before you move on to the next step, make sure to hold on to the milk container assembly.
  4. Anko Milk Frother SB-0802C1 Teardown, Undo the control connections: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger or small screw driver to pry the three connectors off their sockets.
  5. Anko Milk Frother SB-0802C1 Teardown, Separate the main PCB from the bottom: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anko Milk Frother SB-0802C1 Teardown, Separate the main PCB from the bottom: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the white wire, either from the bottom assembly or the PCB.
    • Remove the three small screws.
  6. Anko Milk Frother SB-0802C1 Teardown, Separate the Button PCB from the outer shell: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anko Milk Frother SB-0802C1 Teardown, Separate the Button PCB from the outer shell: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anko Milk Frother SB-0802C1 Teardown, Separate the Button PCB from the outer shell: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the screw that's holding the PCB in place.
    • Use a small screwdriver to push the click finger in. Then remove the plastic button ring and silicon rubber seal.
    • Depress the button and slide the PCB out of its guides.
  7. Anko Milk Frother SB-0802C1 Teardown, Reassemble: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Assembly is in the reverse order.
    • NOTE - The plastic is very soft, so the thread is easily stripped. Turn each screw counter clockwise first, until you feel it engage with the existing thread. Then tighten the screw with moderate force.
    • When sliding the outer shell back onto the milk container assembly, make sure the Button PCB guides fit between the guides on the milk container assembly.
Cees van Egmond
crwdns2935283:008/06/17crwdne2935283:0
186 crwdns2915208:0crwdne2915208:0
Hi Cees,
Do you happen to know more about repairing milk brothers?
I have placed a description of a problem with an Inventum milk frother (see link below).
Can you please comment?
Best regards,
Ernst
(Also Dutch)
My Inventum MK750 milk frother is dead, how to repair?
KolfMAKER - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 930
