Anki Vector Capacitive Touch Sensor Replacement
crwdns2869540:0crwdne2869540:0: 2.2K
4
11
72
2,212
crwdns2955950:0crwdne2955950:0: 7
crwdns2960004:06crwdne2960004:0, crwdns2960006:01crwdne2960006:0
crwdns2959984:0crwdne2959984:0: 4
crwdns2959974:04crwdne2959974:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:05crwdne2931287:0
This guide details how to fully remove the Capacitive Touch Sensor of the Anki Vector.
Remember to only embark on this guide if you have followed the Anki Vector Troubleshooting and the device is still broken.
While disassembling Vector, make sure to look out for disconnected cables and other broken parts, as often times these can be fixed without entirely replacing the sensor.
    1. Anki Vector  Capacitive Touch Sensor Replacement, Belts: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Raise Vector's arms above his head.
    2. Anki Vector  Capacitive Touch Sensor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anki Vector  Capacitive Touch Sensor Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using your thumb and index finger, grab the lower portion of the belt near the large wheel and pull the belt off.
      • Repeat on the other side.
    1. Anki Vector  Capacitive Touch Sensor Replacement, LCD Facial Display: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anki Vector  Capacitive Touch Sensor Replacement, LCD Facial Display: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anki Vector  Capacitive Touch Sensor Replacement, LCD Facial Display: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Using the iFixit opening tool, insert the corner under Vector's golden side panel and lightly twist.
      • Repeat this step on the other side.
      • The panel should pop off without much force.
    2. Anki Vector  Capacitive Touch Sensor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anki Vector  Capacitive Touch Sensor Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anki Vector  Capacitive Touch Sensor Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert the corner of the square end of the spudger under the side plate above the partially visible screw.
      • Lightly turn the spudger to separate the plate from Vector's head.
      • Work the spudger around the plate until it comes off.
      • Repeat this step on the the other side.
    3. Anki Vector  Capacitive Touch Sensor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anki Vector  Capacitive Touch Sensor Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using a Phillips #0 screwdriver, unscrew the two 2 mm screws on the side of Vector's head.
      • Repeat this step on the opposite side.
    4. Anki Vector  Capacitive Touch Sensor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anki Vector  Capacitive Touch Sensor Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pull apart Vector's head. It should separate down the middle.
      • Remove the screen protector by gently pulling it free from the two face halves.
    5. Anki Vector  Capacitive Touch Sensor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anki Vector  Capacitive Touch Sensor Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anki Vector  Capacitive Touch Sensor Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Using your thumb and index finger, unplug the display from the plug in Vector's neck.
      • Pull the LCD and speaker assembly from Vector's head.
      • There is a very thin insulating rubber sheet located at the base of the screen. Be careful not to tear it when removing the display.
    1. Anki Vector  Capacitive Touch Sensor Replacement, Capacitive Touch Sensor: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anki Vector  Capacitive Touch Sensor Replacement, Capacitive Touch Sensor: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using the Jimmy, insert the straight edge of the blade in recess groove in Vector's front wheel.
      • Slowly apply torque to the jimmy until the wheel cover pops off.
      • Repeat for the rear wheel.
    2. Anki Vector  Capacitive Touch Sensor Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anki Vector  Capacitive Touch Sensor Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using a Phillips #0 screwdriver, unscrew the two screws on the exposed wheels.
      • Once the screws are gone, remove the wheels from Vector's body.
      • Repeat this on the other side.
    3. Anki Vector  Capacitive Touch Sensor Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anki Vector  Capacitive Touch Sensor Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anki Vector  Capacitive Touch Sensor Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Gently remove the rear panel by griping it towards the top and pulling out and up.
      • Gently pull out the ribbon cable from the plug between the motherboard and the weight.
    4. Anki Vector  Capacitive Touch Sensor Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anki Vector  Capacitive Touch Sensor Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anki Vector  Capacitive Touch Sensor Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Using a Phillips #0 screwdriver, unscrew the two screws located behind Vector's neck.
      • Lift the capacitive touch sensor assembly off of the body
Shay Takei
crwdns2935283:004/16/19crwdne2935283:0
1,849 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S2-G6, Maness Spring 2019 crwdns2935289:0Cal Poly, Team S2-G6, Maness Spring 2019crwdne2935289:0
CPSU-MANESS-S19S2G6
crwdns2936753:030crwdne2936753:0 72
crwdns2959996:0crwdne2959996:0 2,212
