Anki Vector Battery Replacement
  1. Anki Vector  Battery Replacement, LCD Facial Display: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anki Vector  Battery Replacement, LCD Facial Display: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anki Vector  Battery Replacement, LCD Facial Display: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the iFixit opening tool, insert the corner under Vector's golden side panel and lightly twist.
    • Repeat this step on the other side.
    • The panel should pop off without much force.
  2. Anki Vector  Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anki Vector  Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anki Vector  Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the corner of the square end of the spudger under the side plate above the partially visible screw.
    • Lightly turn the spudger to separate the plate from Vector's head.
    • Work the spudger around the plate until it comes off.
    • Repeat this step on the the other side.
  3. Anki Vector  Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anki Vector  Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #0 screwdriver, unscrew the two 2 mm screws on the side of Vector's head.
    • Repeat this step on the opposite side.
  4. Anki Vector  Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anki Vector  Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull apart Vector's head. It should separate down the middle.
    • Remove the screen protector by gently pulling it free from the two face halves.
  5. Anki Vector  Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anki Vector  Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anki Vector  Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using your thumb and index finger, unplug the display from the plug in Vector's neck.
    • Pull the LCD and speaker assembly from Vector's head.
    • There is a very thin insulating rubber sheet located at the base of the screen. Be careful not to tear it when removing the display.
  6. Anki Vector  Battery Replacement, Battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anki Vector  Battery Replacement, Battery: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anki Vector  Battery Replacement, Battery: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently pull out the two halves of Vector's head from between his arms.
  7. Anki Vector  Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anki Vector  Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anki Vector  Battery Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the Anki Vector's belts on both sides of its body by gently sliding them off.
    • You should be able to pull them off without much effort.
  8. Anki Vector  Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anki Vector  Battery Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull off the covers attached to Vector's rear wheels.
  9. Anki Vector  Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anki Vector  Battery Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anki Vector  Battery Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the 2 mm screws located under the wheel covers using a Phillips #0 screwdriver.
    • Remove the rear wheel.
  10. Anki Vector  Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anki Vector  Battery Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anki Vector  Battery Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the two 2 mm body screws using a Phillips #0 screwdriver.
  11. Anki Vector  Battery Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anki Vector  Battery Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anki Vector  Battery Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using two fingers gently pull off the lower rear panel.
    • Using your fingers, unplug the ribbon connector.
  12. Anki Vector  Battery Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anki Vector  Battery Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anki Vector  Battery Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the two screws behind vector's neck.
    • Remove the capacitive touch assembly.
  13. Anki Vector  Battery Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anki Vector  Battery Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With a moderate amount of force pull one of vector's top arms away from his body until it disconnects from the shaft.
  14. Anki Vector  Battery Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anki Vector  Battery Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gripping the shaft with needle nosed pliers, pull the opposite top arm off the main shaft.
  15. Anki Vector  Battery Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anki Vector  Battery Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anki Vector  Battery Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pinch one end of the arm shaft and push it into the body.
    • Grab the other end and pull the shaft out of the body.
  16. Anki Vector  Battery Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anki Vector  Battery Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anki Vector  Battery Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Raise vectors arms all the way up and gently pull each arm out of its socket.
  17. Anki Vector  Battery Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anki Vector  Battery Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the wheel covers off of Vectors forward wheels.
  18. Anki Vector  Battery Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anki Vector  Battery Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anki Vector  Battery Replacement: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the same Phillips #0 screwdriver, unscrew the 2 mm screw under the wheel cover.
    • Gently pull the wheel off.
  19. Anki Vector  Battery Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anki Vector  Battery Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anki Vector  Battery Replacement: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the two body screws located behind the front wheels.
    • Gently pull the cover from Vector's body
    • Be careful when removing the cover. The infrared sensor connects the cover to the body by wires.
  20. Anki Vector  Battery Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anki Vector  Battery Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anki Vector  Battery Replacement: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently unplug and remove the infrared sensor.
  21. Anki Vector  Battery Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anki Vector  Battery Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anki Vector  Battery Replacement: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert your Phillips #0 bit into a 4 mm nut driver and insert both into your bit driver.
    • Unscrew the three body screws.
  22. Anki Vector  Battery Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anki Vector  Battery Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gradually increasing applied force, pull the body apart.
  23. Anki Vector  Battery Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anki Vector  Battery Replacement: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anki Vector  Battery Replacement: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the shoulder panel.
    • Remove the weight.
  24. Anki Vector  Battery Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anki Vector  Battery Replacement: crwdns2935265:024crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anki Vector  Battery Replacement: crwdns2935265:024crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug the two motor connectors from the motherboard.
  25. Anki Vector  Battery Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anki Vector  Battery Replacement: crwdns2935265:025crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anki Vector  Battery Replacement: crwdns2935265:025crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Wriggle the battery free from the motherboard.
    • Using a soldering iron, desolder the connections from the battery to the motherboard.
crwdns2935229:042crwdne2935229:0
Shay Takei
crwdns2935283:004/16/19crwdne2935283:0
1,717 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S2-G6, Maness Spring 2019 crwdns2935289:0Cal Poly, Team S2-G6, Maness Spring 2019crwdne2935289:0
CPSU-MANESS-S19S2G6
crwdns2947412:024crwdne2947412:0
Ok nice step by step guide but what are the specs for the battery as they’re not visable in any of the pictures…
John Fitzgerald - crwdns2934203:0crwdne2934203:0
Part Number: Li-Ion Poly 500mAh #1578B
3.7V 500mAh
Brian -
Who manages to do all of this in 7 minutes ? Apparently it is a 3.7V battery, question is what is the max size that fits ? 3.5 x 2.5 x 0.4 cm is reported to fit, 4x3x0.5 might as well.
Holger Brueckner - crwdns2934203:0crwdne2934203:0
Any idea where to get one ?
Gordon Hamilton -
Who manages to do all of this is 7 minutes?
me
Kerigan Creighton -
crwdns2936751:024crwdne2936751:0 12
crwdns2936753:07crwdne2936753:0 87
crwdns2936753:030crwdne2936753:0 490
crwdns2942667:0crwdne2942667:0 28,746
