If your Anki Cozmo robot is emitting muffled or little to no sound, follow this guide. This guide is to assist users in replacing the speaker in an Anki Cozmo robot, so it can make noise again. The speaker, located in Cozmo’s head, allows it to make noise. Before beginning, make sure to power off your Anki Cozmo robot and disconnect it from the Anki Cozmo app.
WARNING: when using hands to remove any component, be careful not to cut yourself or rip your fingernail.
Remove the two black rubber treads from the wheels using your hands to pull them off.
Remove the white hubcap from each of the four wheels using the metal spudger to pry them off.
Remove the 7.5 mm screw in the middle of each of the four red wheels using a JIS #1 screwdriver.
Remove the red hubcaps from each of the four wheels using your hands and fingers to pull them off.
Remove the 5.5 mm screw on the right side of the front gold bumper using a JIS #1 screwdriver.
Remove the 5.5 mm screw on the left side of the front gold bumper using a JIS #1 screwdriver.
Remove the front gold bumper using your hands and fingers to pull it off.
Remove the two 5.5 mm screws that lay deep on the right side of the gold body using a JIS #0 screwdriver.
Pry off the two white arms from the right side of the body and the two white arms from the left side of the body using two metal spudgers.
Pry off the arms by digging the tips of each spudger in between the arm and the body and pushing up away from the body.
Remove the long white spring that is attached to the right short arm from the center of the body using your hands and fingers to pull it out.
Pop off the two red square fascia from both sides of the white head using the metal spudger to pop them off.
Remove the two 5.5 mm screws from the right side of the white head using a JIS #0 screwdriver.
Remove the right side of the white head using your hands and fingers to pull it off.
Pop out the black cover screen from the left side of the head using your hands and fingers to pull it out.
Remove the left side of the white head, along with the two short white springs that are attached to it, using your hands and fingers to pull them off.
Unplug the black LED camera screen and the white and gold speaker from the small white plug in the center of the body using your hands and fingers to pull it off.
huuyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyuuuuuylllllutfliuhgpiuhioihikjcdyhpispiuhpujgpiushpiuhpushpiuhoiudjdoigspouse[ouitg[soujos;etjh'sjs'ohsphporhg;ohgpiuhgpsehislergoiarkishoisherog9shgohsiouhgiehrguhsiueghirgiuhgriurgiuehgpiuisehgpisughsieuhgoushgiouerhgpuhgishgipuehgrioehgioushoriguhesoiurhirhiushpgireuhgpiuhrgpiushpiyhaiouahiusiaihgiuriuhgiuaheupairehuaioweoiaoirwjpoariouhaowijfoueraghoiwrao[iegosua[joseigiouerpogi[eroigjsoperijgopsirgoeurgoud;oijgapoeirgousehgpihvspiurgiuhapiuwhepuifh[aowuopuawrh[gopoireahgourhgoihroirjguioaegouhouhero;iugoirwgipoaoijerogouahr;oihohaghu[gr[uha[ruoeo[hugraeh[ouhruegiprwuhapohg[ouherpuispeuogpoheroguppiuapiuhwriuhapghrhuowapohagphuerpguhaepughaeruighapeiurgiuperhgihpoargpoaglogoeuragpoauerohaergluhilerglaeghloegaeihgaghhiupapiouliroiughlaghloshglopouarhgoaelsliuhrguhgp;iosghirpuhgphersugpuhphaepighuro;si wheres do you buy thr speaker
Also, I need to know which speaker model to buy and where to buy it?
