Anker Soundcore Space Q45 Battery Replacement
  1. Anker Soundcore Space Q45 Battery Replacement, Plastic Covering: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the iFixit opening tool to disconnect three clips holding the outer covering in place.
    • Clips at 3 o'clock, 7 o'clock and 11 o'clock
    • Image shows right headphone, battery is in left.
    Battery is in left side, three clips to release
    nic... - crwdns2934203:0crwdne2934203:0
  2. Anker Soundcore Space Q45 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anker Soundcore Space Q45 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove three screws holding the inner plastic covering in place with a Phillips screwdriver.
    These photos show right side, left side with battery has ribbon connector for charging port.
  3. Anker Soundcore Space Q45 Battery Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anker Soundcore Space Q45 Battery Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull out battery to USB C ribbon connector from circuit board
  4. Anker Soundcore Space Q45 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anker Soundcore Space Q45 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull directly up on the battery to release it from the tape holding it in place.
    • Battery terminals must be de-soldered to remove fully
    Battery is soldered to board under adhesive pad
    • Battery dimentions - 35mm x 25mm x 6mm 750-800mah 3.7v
    The exact kind of LiPo being used is the 632832, from what I can tell
    WannabeSpaceman - crwdns2934203:0crwdne2934203:0
  5. Anker Soundcore Space Q45 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Replacing charging ribbon is tricky, use tweezers to reach through square hole and reconnect
Benjamin daCosta
crwdns2935283:003/19/24crwdne2935283:0
669 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 4-3, Shaddix Spring 2024 crwdns2935289:0UMass Dartmouth, Team 4-3, Shaddix Spring 2024crwdne2935289:0
UMASSD-SHADDIX-S24S4G3
Hi. The microphone quality of Anker Q45 is terrible. Do you think it is possible to replace de microphone for a better one?
Perry Picoli - crwdns2934203:0crwdne2934203:0
Can you show a close up shot of battery? I want to identify its size and other specs...
Steven - crwdns2934203:0crwdne2934203:0
Look for a 632832, but you might have trouble acquiring a single unit, unless you're okay with waiting a month or two with aliexpress shipping
WannabeSpaceman -
Welchen Ersatz Akku soll ich verwenden?
Andi - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 43
crwdns2936753:030crwdne2936753:0 165
crwdns2942667:0crwdne2942667:0 2,453
