This guide will help you replace the Anker Soundcore Motion Boom Plus tweeters. The tweeters are the smaller speakers on the side of the device designed to reproduce high-frequency sounds. If your device is experiencing distorted or crackling sounds, the tweeters may be damaged and require replacement. Be sure to turn off the device before taking it apart and use the tools recommended to avoid any damage to the device.
Insert an opening tool into the seam between the speaker grille and the chassis.
Pry the tool around the top, bottom, and sides until the grille fully releases.
Remove the grille.
Remove the two passive radiators on either side of the device.
Remove the sixteen 14 mm Phillips screws, eight on each end of the speaker.
Gently remove the handle from the device by clicking off the handles from the sides and then pulling it off.
Flip the speaker onto its side and use a spudger to remove the two rubber feet on the bottom of the device.
Remove the eleven 13 mm Philips screws that secure the driver housing.
Remove the two 14 mm Phillips screws located on each side of the handle, near the clip points.
Remove the four 14 mm Philips screws on the top of the device.
Insert a spudger into the seam on top of the device.
Gently pry the casing open.
Disconnect each of the three cables by gently pulling the connectors out of their sockets.
Disconnect the ribbon cables attached to the tweeters by pulling them off gently.
Push the tweeters from the front side, and the tweeters should pop out. Remove and replace the tweeters with new ones.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
